Racepace Built R34 Gtr Nur Rb28 V-cam
Amazing thread to go with an amazing car. Your choice of parts and the carbon/colour combo couldn't have been more spot on!
Add me to the list of people waiting for the vids!
Can't wait to see the feature, any idea what issue # it will be?
If you have a spare 100k then you should give it to me. Saw this cars absolute twin the other day...not sure I would want the identical car running around...but cant blame two cars turning out very similar when they are such great things
Must be that Silver one with same mods in GTR.co.uk site... but So nice.... would probably end up copying inside Carbon idea, when i get mine... Everything else in this car is so out of the average Joe "Mine" budget, it's not funny. where those video's
I started reading this thread a few months ago when only the teaser pics were up.
Found the thread again and spent all night reading it.
Perfect, tasteful, powerful R34 GTR. This over a R35 anyday. :P
How's your gearbox holding up by the way?
  • 3 weeks later...
Hi all,
Just a quick update on the suspension upgrade with Racepace customised Tein RS setup.
The Tein RS, aka 'Circuit Master; Super Racing Spec', has been out of production since 2006-2007. They were the top of the line in the Tein catalogue for production cars at that time. In some ways, I feel that the materials used and the way it was manufactured surpass what's commonly available today, even the premium priced shocks.
Details of the RS are listed below (sourced from US based my.is forum in 2002)
MATERIALS AND FACTS:
DAMPING MECHANISM:
45mm diameter pistons
Double shim stacks (near unlimited tunability with knowledge of shim valves)
Two 'special form' adjustment needles
SHOCK/RESERVOIR BODY:
Monotube shock body
53mm outer diameter
Aluminum alloy (A7050) seamless tube, CNC'ed, green (hard?) anodized
Inner tolerances:
diameter: ±5µm
roughness: ±1.6µm
Reservoir body interior is PTFE (Teflon) coated
CNC'ed aluminum alloy eyelet, Tein rubber bushing, steel pivot
SHOCK SHAFT:
14mm diameter
Chromoly (SCM435) steel, Ti-N coating
SHAFT SEAL/GUIDE:
WRC spec
PILLOWBALL MOUNT:
Aluminum alloy, CNC'ed, powdercoated (gold)
SPRINGS:
Main and helper
Steel, ground and tapered, enameled
10K front, 10K rear
SPRING PERCHES:
Aluminum alloy, forged and machined
SETTINGS:
-34mm front, -12mm rear (easier measured as 335mm both from the center of the wheel to the fender lip, front and rear)
10 clicks rebound front
10 clicks compression front
10 clicks rebound rear
13 clicks compression rear
Out of the box, the RS will not suit my purpose of a street orientated setup in Australian conditions. So the solution Racepace derived is to employ a high quality, well engineered shock to begin with and customise the valving and spring rates.
The current spring rates are less than half of 10K front and rear. The exact rate Racepace did not divulge and so is what they did to the revalving. BUT believe me, the setup works very very well.
My initial impression, compared to the Nismo S Tunes, which is also street orientated:
- The damping is comparable, soaks up bumps and road undulations well. The rebound is quicker than the S Tunes, that the RS is less 'cushy'
- The car feels more planted and can hold its intended steering path despite mid corner bumps etc
- At very low speeds, the RS is very compliant
The only annoying thing is an annoying 'whimper' originating from the rear shocks at very minute bumps. It almost sounds like someone rubbing a wet finger on clean glassware. However, I did some research and found that this is quite common, and indicates no fault. The pillow ball mounts also transfer more road noise to the cabin.
I spent a good afternoon with Chris from Racepace. And this is how I feel as a passenger..... Well Chris test drove the car in a 'hill' run. (Chris is an excellent driver btw. He scared the sh*t out of me)
- The car feels like its on tracks and bumps do not upset the momentum.
- Car feels planted, period!
Chris comments that the RS allows him to transfer weight nicely and from the get go the setup is confidence inspiring. That is he can drive a lot quicker if I was not in the car with him. He was extremely happy with the way the RS can handle the low speed stuff equally as well as the high speed.
Overall, I am very impressed, bearing in mind that the Nismo S Tunes were very good to start with. I highly recommend it to anyone wanting a street car to go for less spring rate but good damping force.
Final thing on the agenda - increase ride height on front end and transfer case reinforcement.
PS will post pics on weekend.
Cheers
Matt
can still buy the tein RS from tein japan :)
can still buy the tein RS from tein japan :banana:
oreally? I can only see reference to "super racing spec" on their sites which I believe were the same thing, but everyone reports them as being discontinued.
I am up for a set if this is true and someone can speak Japanese!!
Hi all,
I am totally amazed at the continued support and interest in my build.
Regarding some of the queries:
The gearbox is holding up well despite the extra power. I guess I do look after the gearbox by avoiding any hard launches.
Second hand Tein RS still pop up every now and then on Yahoo Japan. You need to check frequently to find them and they do sell rather quickly. I sourced my set with help from Import Monster.
I am looking forward to the Performance Import featuure article. However, I have received no news as to when it will be published or even seen proofs of Jun Sawa's work. They are certainly keeping me in suspense.
Cheers
Matt
Matt Im so glad you have had your PI shoot. with mine still a couple months away it almost gaurentees i wont be in the same magazine haha...which im very thankful for.
Must be time to use your modifying talent on a 35 now too :(
Hi all,
Cheers
Matt
Hey Matt,
I will be in touch to catch up soon.. i do believe its out January but will confirm.....
  • 5 weeks later...
Hi guys,
Its been a while since an update. I finally got around to posting the pictures below of Tein RS before the installation.
Yes, you are right, that is a another set of Tein RS in one of the pictures that Racepace was modifying at the time my set was being done.
Eibach coils
custom aluminium spring seat:
I will take installed photos soon
Cheers
Matt
    • Ahh yes looks like I’m playing with a new cock on the weekends. Thanks for the information @soviet_merlin I’ll search for it later on and try to get it shipped. Looks like it won’t happen this weekend regardless. But the coolant looks fine so far (no floaties of concern). And waiting another week will slow down my money hole 😂
    • I don't know whether that one should be reused or not. But here's one way to find the part. Go to https://nissan.epc-data.com and use frame number or the menus to drill down to the parts for your specific car. Looks like it is under 'Body parts -> 214 radiator'. See for example the respective part for my Stagea. Looks like it's called drain cock packing, and at least for mine it is part number 2148118000. Searching for that then gives you various places where you can buy it. Amayama can be a bit slow, so it's worth searching around. I'd make sure it's the correct one for yours. At least from amayama it looks pretty generic and fits a ton of cars. And if anyone asks what you did on the weekend, you can tell them that you put a new cock on the car
    • Because people like Gregged stories, I'll elaborate. I ordered a front end, being a GTR conversion front bumper, CF hood, to go with my URAS wider front fenders. These took a good ~year to arrive. They had arrived when I dropped them off at paint shop 1 and are in that large pile of car panels. Unfortunately _some_ of it didn't fit very well/at all, though to be more accurate it's safer to say it didn't fit with each other. A lot of GTR conversion parts, really are just GTR parts. GTR fiber replicas need GTR guards. Because GTR fenders flare out more than GTT fenders. Even GTT fenders that are flared out by the same amount GTR fenders are. The GTR conversion/GTR bumper I was sold is no longer for sale as the company involved recognized the issues with it and refunded it, beyond this situation. The bonnet and bumper gap was... this. They then sent a redesigned bumper, but this still had the issue with the width, and then advised me I needed GTR bracketry to fit this conversion bumper. Which, to me, is kind of crazy - Because if you need a GTR Reo, headlight supports, headlight brackets, and the mounting bracket (with the additional plate with the rubber strip) in order to mount your 'conversion' bumper, the bumper itself is just a GTR bumper. And when I mentioned this, not to mention the time and hassle of sending bumpers back and a forth and dealing with a busy company, I was able to make the statement that this is not made to fit a GTT at all, at least in the sense that you can't use any of it with any other GTT part. The bonnet worked, but without a bumper that can actually fit it was effectively just a GTR bonnet with GTT hinge points and latch points. Not much use if I can't use a bumper. Why would I (or anyone) buy a fibreglass GTR replica that costs more than an OEM plastic GTR bar, if I need to use all the GTR hardware to mount it anyway? Funny enough I had test fitted everything else except these bits. Obviously I should have. I saw pictures of things fitted but everything's not quite the same and unmentioned the fact people have made extra brackets or something to pull on these fibreglass bumpers. With the GTR brackets we were able to force the "second" bumper they sent us, but you shouldn't need two big guys forcing a fibreglass bumper over mounts you need to drill to get it to fit, using a lot of tension and a lot of force, the whole thing was completely taut and felt spring loaded to explode at any moment. In any case after all this faffing about, I eventually spoke to someone else at this company who advised I should have been sent the correct parts to begin with given they pulled up all my communications with what I had, what I wanted, what parts I was using, etc. But by this time the car had been sitting at Shop 1 for quite some time now and they didn't really just want to paint the rest of the car from A pillar back while this was all sorted out. I got a full refund and honestly everyone involved was perfectly nice and easy to deal with once I could get ahold of them, though it did need a bit of 'chasing' as you kinda expect. So then I had a stock front end again, and could have just fit the URAS fibreglass fronts and used an OEM front bumper and OEM hood and called it a day. But did I do that? No, I am retarded. Because I was paranoid about Mr Police in the future sticking a magnet to my front guards, or my bonnet and realising they weren't metal, I followed up on a tip I got from a friend who got his metal guards widened out. I had wanted to do this 'in the future some day' but thought I may as well just do this 'now' given I'd be driving around all paranoid about my fibreglass front fenders on my otherwise legal and engineered car. SO ANYWAY I engaged these people during the time I was returning the original body parts, so the car was at Shop 1 with no front end at all, not being fitted or being painted A pillar back even though I was more than happy to just get the front panels painted separately when they existed. (I understand the reasoning for not wanting this, but I was just trying to save time). And you guessed it, the metalbenders took much longer than they said they would take, and Shop 1 man had a medical issue where he had to close the shop indefinitely (legitimately).  So even though I had to return a bunch of stuff, and a car sat around for months with no work being done on it, there's no actual bad blood there, so I don't want to name names and say "SHOP X SUCKS" just... do your diligence. Metalbender place returned my Bonnet and Guards to me eventually, which was when I realised THIS: Is going to make my life hard again, because having wider metal guards doesn't make much benefit if the actual point it hits is the connection between the bumper and the guard. Which is why Nissan flared it out, ostensibly.   With regards to the bonnet, I needed vents in the first place because the car likes to overheat due to heat soak on 40C days with the aircon on, if the car has been driven for more than like 30 minutes. Only with the aircon on, only on days that hot, only when sitting, and only after ~30 minutes. So the logic behind it all was to cut vents in. I had originally thought to just the flat pieces out (not the webbing!) and put mesh in there, which would have worked fine. Then talking to the metalbenders I was convinced this was a bit agricultural and water would get in. STUPID EVERYONE INVOLVED didn't think of simply using a plastic engine cover on the engine, and we started talking about vent design and rain gutters instead. There was also the issue of while the guards both fit what I asked for, which was: "Can you replicate these URAS Fibreglass flares on these stock metal guards by the same distance, or maybe +10mm wider?" ..the issue was the guards weren't the same as one another when the job was done. Enough that when I fit them and went to paint places, the overriding feeling was "I can't get it painted while they're like that". So, I Karen'ed and they offered to fix them up to get them symmetrical again after I drove back and showed them, and we did the whole lean back from a few meters in front of the car, and: "Oh yeah" "ahhh yeah".. "Ahh, ... yeah, yeah nah yeah" ... and I then took them off and delivered them. I have it all back now, and while the guards are better they're still not symmetrical, and I'm paranoid about a tiny bit of webbing actually being cut with the vents installed, and only slightly remorseful about the fact that METALBENDING WAS REALLY EXPENSIVE, and it would have been cheaper to simply buy all of the Nissan OEM pieces, including $2200 aluminium bonnets, and $2000 guard sets and OEM plastic bumpers and get it done that way. YOU ARE WARNED. also, anyone wanna buy my GTR brackets between the headlights? Useful for someone doing this conversion and they cost about $1000 cause you didn't want to use/mark up/damage the fibreglass replica the company sold you to make their stuff fit (it won't fit).
    • Thanks gents, I think I'll get a PSR and see how it goes. I saw an interesting video in YT where a guy stripped one and the bearings were similar to the GTX series instead of the newer G series, but for 40% of the Garrett price I suppose there has to be some sort of trade off!
    • My opinion is they aren't worth double at all.  Have used a good number of Pulsars with builds I've been involved with and tbh at least speaking for myself, Garrett aren't losing money they'd be getting if Pulsar didn't exist as for genuine Garrett money I'd probably be buying something other than Garrett.    We've used Pulsar 6262G (G35 900 equivalent) on an RB26 with a twin scroll hotside and it picked up 40wkw at the same boost over the old twin -5s and the improvement in transient response over the twins changed the car - this is before you factor in the amount of further headroom of the G35.  Have also used one on a 2JZ drag car which has run 9.6 @ 141mph not even trying, from what we've seen so far it'll potentially go 8s when we turn it up  Crazy results for what is basically a NZ$1500ish turbo.
