Matt,
I am in awe of this build of yours. Coming from a Nissan S15 and continuing my journey with a Storm Trooper Evo X MR literally tossing up as you have pointed out to a R35 you make me regret my decision of buying a White R34 and doing what you have done, which was a 3rd option.
I really hope we can meet one day as like yourself, I am obsessed with white car, black carbon bits and black wheels.
Tell me if I am wrong but it appears your guards aren't rolled yet it appears that you want to do track days? Have you considered a respray in a better white maybe with a distinct pearl?
  • 3 weeks later...
DYNO RESULT:
This is the email Beno sent me when the car was ready for pickup. I will let someone who knows about GTRs summarise what the RB28 V Cam feels like on the road:
The all important dyno graphs:
RB26 NUR vs RB28
RB28 Power vs Boost:
RB28 Power vs Lambda:
Will post pictures of car this afternoon. Need to clean car first!
was this tune on race gas? as someone pointed out, your lambada = 12:1 a/f. little too lean for me with that much boost, if it was on pump gas.
pump
blitz, i think the tuner may have half a clue on how to tune a GTR when a) has built/tuned a 33 R that was only about 1.5 seconds off a v8 supercar around sandown in full street-trim, b)done something on this build that many thought was not possible without a HKS ecu c) have countless other GTR's getting around oz seeing plenty of track time, from weekend warriors to Targa events.
i think it's safe to say the tune is more than fine
pump
[/quote
gotcha ya. btw. what is the octane of pump gas?
Matt,
thats the only way to build them, trust me dude if u saw his car in the flesh u would love the paint work its clean as f**k....
Hey,
Have been trying to find the info in this build but i think there is way too many pages..lol
Would like to know rpm and psi this beast runs to make its power, for interest sake to compare to my setup. Also what head work has been done if thats ok :)
Congrats on this build ;) . Awesome awesome machine...
subscribed - what a beautiful gtr u have there.
with 412kw, is this running e85 or pump? also, what level of headwork do you have i.e. porting, cam specs?
hahah, Marko mate, 3 of the 4 posts above you talk about the fuel!
From my chats with Matt the car has had some headwork, and as far as cams it does have V-CAM so not sure if only one or both cams have been replaced.
Still remember the day I took it for a drive after completed. Truely amazing.....
Thanks for everyone's interest in this thread still.
I believe the my car will be featured in the January 2011 Performance Import issue, at least that's what Jun Sawa (photographer). He also said that the photos thurned out amazing! He is not allowed to show anyone the photos until the magazine article release due to copyright.
As for the queries:
412RwKw output on pump gas, that is 98RON, is definitely possible. Its not the top end power that is amazing, its the low end torque and response that make it fun to drive.
A/F ratio might be on the 'lean' side, however, the car is tuned for street application mainly. The very occassional and brief high boost/lean exertion with street driving should not pose as any risk to engine life. If I were to track the car, Racepace has suggested detuning the engine for bigger safety margin.
Regarding head work.... I am unsure. I know a fully reconditioned RB head was used for the build, but I don't know whether Beno did any sneaky tweaks to it though. If he did, he was not prepared to tell me. Trade secret I suppose and I respect that. The cams are very mild (IN 248; EX 256) and suited to the Garretts -5s.
The V Cam certainly makes a world of difference. Pity I don't have direct dyno comparison on the same engine/turbo setup with and without V Cam.
Sorry, I don't have a power output vs rpm dyno graph. I guess you can convert vehicle speed to engine rpm by knowing what gear the car is running when dyno was charted.
Thanks everyone again for comments!
tangomatt - wat boost you running on the 98ron and whats you rev limiter set to? im sure u have no need to rev this motor out...hence getting the v-cam and extra capacity.
street driving, this thing would be amazing :)
sometimes i wish i kept my setup on the sane side..lol
:thumbsup:
:thumbsup:
Looking at the graph above it looks like it's around 22psi of boost.
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
