Ok, I'll be the first one to say, DON'T DO IT!
Those 'bling' wheels in my opinion don't belong on a car of this calibre, this car deserves the best motorsport wheel and it's hard to pass on the TE37. the work wheels will be considerably heavier and you will definitely notice your car feeling more sluggish.
This car is the epitome of a hardcore street/track car and in my opinion needs lightweight forged monoblock goodness.
I'd say you may also have issues getting them over the AP's aswell.
Another thing I don't like about these meisters is that they use the size spokes as the 18'' version, only the outer part of the rim is larger and in my opinion does not give the full 20'' look.
Anyway this my opinion and many may disagree, just thought I'd give my 2c worth......
P.S if you do decide to go ahead Matt I've got first dibs on the TE's!!!!
TE37s are getting overdone these days imho plus meisters look sick on 34s, proof:
but matt, to run wheels that wide with such low offsets will require some serious tyre stretch+camber to get in the guards and considering the look youve gone for with the car, i dont think theyd suit. the above car has 10.5s rears (unsure of offset but doesnt look like -6)
however, points will be achieved for toughness
I know what your saying Jack but this car doesn't see the track so increase in wheel weight not a huge issue IMO... sluggish? with 400rwkw!? it might not feel quite as sharp but won't be that much of a difference
I agree with Pete, everyone has TE's, can't hurt to try something a bit different
he has the wider Z tune guards up front so just the rears are a concern... the rears in that pic could be close to -6... heaps of dish there
can anyone confirm what offset needed to fit 10.5s on the rear of a 34GTR?
Personally, I love the tough look of the Work Meister S1.
But I certainly understand Jack's point regarding unsprung weight etc etc.
As mentioned TE37s, CE28s, LMGT4s (all of which I have owned) and other popular Volk Racing wheels are so overdone on BNR34s.
I am a wheel whore, therefore i am always looking at other exciting wheel matching for my car.
These were the original pics that got me hooked on the Meisters. This particular set was traded on this forum in 2008/09 and changed hands twice as far as I know. The set for sale in Sydney may very well be the same set of wheels transferring ownership again...
Looks almost Tonka (toy) tuff!
As always, I appreciate the input
Cheers
Matt
In agreeance with Pistol Pete, When i went for the SSR SP1R's on mine i had the choice of those and about 3 different spec'd TE's. Although i absolutely love the TE's they are getting pretty common same with GTC's and CR Kais are getting around a bit more. Yes all very sweet and tough rims but with that size and off set you can't go wrong!
Just got car back from Racepace. Verdict: I like the way the car handles now!
Boring photo of Hicas unit removed. Note 5kg weight reduction.
Custom Racepace Hicas bar,retaining OEM tie-rods. Racepace logo is a nice touch.
Again, it's nothing exciting. Note 4" exhaust sits very close to rear differential housing.
Cheers
Matt
Just curious Matt but how many bonnet's do you have? Ive counted two R tune nismos and a vspec 2 bonnet so far. Add that to your wheel collection and you must have a double bay garage for just storing all the gear to mix and match the appearance of your car! Im hanging out to see your "cleaning out the garage" sale thread in the parts section.
those cars with the meisters arent his
I decided to read this entire thread start to finish meticulously,this was around 6pm WA time,here I am 8 hours later at 2am in the goddam friggin morning LOL.
That said it has been well worth the read and congratulations for such an amazing car,Racepace have done an exellent job,it truly is inspiring.
I decided to renad this entire thread start to finish meticulously,this was around 6pm WA time,here I am 8 hours later at 2am in the goddam friggin morning LOL.
That said it has been well wheorth the read and congratulations for such an amazing car,Racepace have done an exellent job,it truly is inspiring.
i started reading the first post on my ph at work.......no work got done...battery went flat ....raced back to my room to charge and continue reading ....the best post iv read ..
it was like xmas when matt brought new things... great job with the car matt.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
