Hi Matt a great job a Nur spec built to full spec lol.
Im from africa interested in your old motor do you still have it tried to pm you ?
Let me know
Cheers
Adam
Hi shiro ryo
I don't quite understand what you may be referring to? Please elaborate.
Thanks
Matt
I don't think he understands what he is referring to either.
All RB26 R32-R34 head castings are all the same. There is certainly nothing you can identify from looking at the outside of the head.
Looking forward to seeing what you'll do to an R35 if thats what's next Matt.
Hi Shiro Ryo
I switched the NUR engine out because I wanted increased capacity RB. Its amazing what just an extra 0.1771 L of capacity can do to transform the way the engine performs.
I sold the NUR engine as a whole with the Gold cam covers because that usually is worth more money.
I went for black cam covers to match the theme of the car - black and white.
Matt
  • 4 weeks later...
I absolutely LOVE this car.
The black and white, CF bits, Z-tune bits, V-cam, steering wheel, TE37's... EVERYTHING is perfect.
I've always wanted a Nur/Z-Tune R34, and this is probably the best example I have ever seen. I've always loved Bayside Blue, Midnight Purple and Millennium Jade, but the Black on White has changed me, or at the very least added to the list.
Thank-you. Your car is Incredible.
Chris
Hi Matt
The car that will be on the front cover of performance imports 134 is my R33 GTR time attack car you saw it at RacePace last year jack was dropping it off. This will be a great issue tuff track and street GTR's.
Matt - Jason...
Will send some photos just before the magazine issue is out so that you can post some pics on here.... i hope the features look good otherwise the skyline australia peeps will hunt me down :P
Yes, my car spends more time at Racepace than my garage! I am always picking Chris's brains on how to tweak the car more for better performance.
I just got transfer case modified to allow more power to be diverted to the front wheels when power on. This supposedly gives better traction when launching and on corner exit.
I had Hicas removed as well to allow a more stable rear end when cornering at moderate to high speeds. The factory setting of Hicas gives the car a rather unstable feel to the rear end. Besides, all of Racepace circuit and targa cars have Hicas deleted.
Therefore, two more boxes ticked!
I also underwent another re-tune on the dyno and Chris discovered a minor lean spot just as the boost comes on that needed some adjustment. Just a word of advice, dyno-tuning needs to be carried out periodically as the GTR tends to get out of tune with mileage. Power at the Rear wheels was slightly down from 413 rwkw to 407 rwkw (humid day!). Boost levels slightly down, probably due to high barometric pressure.
All other systems were checked to ensure optimal operation and the car is thankfully A1.
Hmmm... just a few more thing on my list to be done.
Finally, thank you all for the continued interest and support. This thread has over 100,000 HITS!!! :thanks:
Guys, I almost forgot. I would like to buy these wheels....
Specs:
Second hand Work Meister S1 20"X10.5" in chrome and get this - Fr offset 0; Rr offset -6.
Cost: NOT cheap
Discontinued specs, rare
I did a bit of calculation and the front is going to stick out 21mm more than my TE37s and Rear by 27mm.
Couple of questions:
Would the wheels clear my AP brake calipers?
Would the inner rim clear my Tein RS?
Would the outer guard rub on the rear guard?
what are the specs of your current wheels?
how much room do you have between rim and shock at the moment?
whether the tyre rubs on the guards will depend on things like tyre width and sidewall height (how much stretch you have)... and camber
those rims come in different 'disks'... it simply means how far out the spokes are pushed towards the outside of the rims... you can have 2 wheels with the exact same width and offset but one will have the spokes pushed out further to accommodate big front brakes
brake fitting is a trial and error thing mainly... TE37's are really well designed for clearing large calipers... Work Meisters, not so much
if you can get them to fit they will look fantastic... but will be some dicking around... most importantly fitting over the brakes and not fouling on the shocks are most important... the other stuff can be worked around
EDIT: worst case scenario you maybe able to run spacers... but on a car like your I dunno about spacers... ask Chris about that
if you did buy them and then find they dont clear your brakes you certainly wouldnt have any problems selling them again
i wouldnt think clearing your struts would be an issue with that low an offset either
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
