The CE28's look the best I reckon... LMGT4's are definitely cool though... tough choice hey!... top shelf parts selection and you got it built at the right place... now stop holding out on us, we want to see the dyno chart!
Agreed the CE28's are my favorite wheel. :domokun:
A Power FC retune yielded a slight increase in maximum power output, possibly due to larger intercooler:
I will keep this thread alive by updating periodically
Hi,
Just wondering, this power was achieved on standard injectors or?
What boost pressure did was it on?
Beautiful 34 you got there, keep up the good work.
Cheers
Grant
Hi,
Cheers
Grant
Hi Grant,
The power output was achieved with standard fuel pump; standard camshafts; and standard injectors. Its surprising sometimes how good the factory stock parts work.
The boost pressure was about 1.3 bar, with NO electronic boost controller, just HKS actuators and a factory solenoid with a bung in one of the hoses.
I guess that is Racepace tuning philopsophy - keep it simple and achieve maximum result! (BTW I have no affiliation or financial interest with Racepace.)
Cheers
Matt
Thank you for all comments and encouragement!
Better do something bout those brakes. Look a little small behind those rims.
Since someone mentioned brakes, below is a detailed pictorial of the AP Racing 6 pot front; 4 pot rear Formula Big Brake kit.
Front caliper 6 pot CP5555:
Rear caliper 4 pot CP7618:
Size comparison:
Front mounting bracket at an amazing 0.8kg and super strong
Front 'Strap Drive' 2 piece slotted 355mm disc:
Rear one piece cast slotted 320mm disc:
Interesting to see that the front disc at larger diameter weighs less than the smaller cast rear disc.
Ferodo Racing DSC 2500 pads (should've bought DSC3000 instead.. DOH!)
Braided brake hose and tubing:
Dot 5.1 AP Racing brake fluid:
Final installed:
GTS4WD Posted Today, 11:49 AM
Stupid qestion one for the day:
What is V-cam?
V Cam = HKS variable cam on intake side for RBs
Aaron34 Posted Today, 12:01 PM
Hey, you should have just bought my car instead and saved yourself a fortune... What exhaust are you putting on it now if the RPM single is coming off?
Hey Aaron,
It would have definitely been alot easier just to buy your car, but then I miss out on all the fun and excitement of building my own car to my own specs.
In terms of cost, it ended up almost the same as the 'trade in' price you wanted for your car at that time :laugh:
One of my friends is interested in building a RB28 GTR, so I will try and convince him to look at your car if its still for sale!
As for the exhaust, I had one made similar to what Ben has in his R33
Pictorial of HKS V Cam unpacking:
Special Intake Cam "V CAM" : 248° Valve Lift 8.6mm, Phosphate Treated:
Special Intake Cam Cover (HKS POWER logo gives extra street cred):
VALCON(V CAM Specific):
Nickel Plated Duralmin Intake Pulley:
Extract from HKS European website:
Using variable valve timing technology, V Cam System evolves the RB26 engine to a new level. HKS V Cam System for RB26 addresses the issue of low-mid rpm torque whilst allowing the engine to continue producing power at high RPM.
Features:
The intake cam side of the RB26DETT is changed to allow variable valve timing. The Cam used has a duration of 248° which can seem a little conservative. However with the variable timing, power increases can be found at low or high RPM
Whether you are looking to find some time on the circuit through improve acceleration out of lower speed corners, or simply want something which can overtake with ease on the street, the HKS V Cam System provides good power from low RPM reducing the necessity for excessive gear changes. This especially noticeable when going from vacuum to boost to give the feeling of increased displacement.
Improved valve timing will allow for more complete combustion leading to improved fuel economy and cleaner exhaust emissions.
HKS V CAM System is available in 2 versions. Type A, which can be fitted to a standard engine (Valve timing adjustment 30°) and Type B, which can benefit from further valve timing adjustment (50°) through the use of HKS Pistons.
Type A was chosen as car is intended to be street orientated.
Hey Matt
Did you import the V Cam kit yourself or did you buy it from an HKS dealer here. The reason why I ask is if you bought it from o/s, you're going to have a tough time getting it tuned properly in this country as HKS will not supply the software to tune the kit unless you bought it through an Australian authorised dealer. Someone I know went and bought his kit o/s, got it installed through Bel Garage but could not get the software to tune the damn thing.
So just be wary of that.
Hey Aaron,
Either you haven't got your labour bill yet, or the parts you bought are hot. At my advertised price of 89K, I'm not sure how you could build up one of these including the car purchase price. I know mine has over 100K spent on it then there was the price I paid for the car itself...
I'd love to get around to putting the variable cam set into mine one day. Its already insanely torquey with the 2860 -5s and the 2.8 HKS step2 kit.. (plus all the other top secret stuff of course) I'm still running the standard intercooler and plenum. I see you changed both of those... Is your's running yet? I heard it might be..
mxfly Posted Today, 06:44 PM
Hey Matt
Hi mxfly,
I had this discussion with Racepace prior to ordering the V Cam and Ben guaranteed 100% that he will be able to integrate it with the Power FC with no software of hardware technical problems, and guess what... the man delivered! I privately imported the HKS V Cam direct from Japan. I managed to find a copy of the installation and software set up manuals in English which helped a lot.
two_evil Posted Today, 07:02 PM
yeah exactly i think you need to use a hks f con v pro to use the v-cam. other wise u can't tune it. sucks ass. i think you might be able to haltech to control not 100% sure
Hi two_evil,
I was a bit sceptical at first whether the V Cam will be compatiable with the Power FC, but the result has proven that it works very well. I was told that the Valcon does not talk to the Power FC at all, it merely acts as a piggy back computer changing the Cam angle according to engine speed in rpms.
Initially I was going to buy the HKS f con v pro, but the cost is prohibitive and HKS will not sell you one unless you purchase direct from the Australian distributor and on top of that, no one can tune a F Con except the distributor in Sydney.
I took a bit of a gamble to outlay the cash for all this V Cam stuff when I only had one man's word that he can make it work. It just shows how much I trust my workshop.
Aaron34 Posted Today, 08:10 PM
Hi Aaron,
Your car now at $89k is an absolute bargain for what you get! Back then when I inquired you about it, you were a lot firmer with the price.
LOL regarding the 'hot' parts.... I actually have good contacts which allowed me to get exceptional deals on JDM car parts, besdies the Aussie dollar at the time was in my favour. I must admit the labour cost was the killer. Don't forget your car has fully tuned suspension, drivetrain etc. which my car does not.
The car is running well, I will post dyno graph soon.
Matt
I hear it is awesome. We should meet up and swap some knowledge. I'd love to suss out the VCam and I'd be happy to take you over the rest of my car and where all the time and money has gone...
Beno knows how to hit the bullseye with all of it now, but it took time. The 33 is a totally different chassis. Great thing with Beno is you feed back the cars behaviour and how you want it to behave and after an exchange of time and money, you get exactly what you want. I don't know anyone else that can do that as well.
I've only put about 3000 ks on mine in the last 20 months, basically since the build. Damn waste. Winton in a couple of weeks should be a good test for it...
Hey Aaron,
The issue I have now is that the car is too fast for me to handle safely, I get scared when I go full throttle. :)
I wish I had driving skills like yourself, Chris and Jack.
I need to learn how to drive the car! Definitely catch up.
Cheers
Matt
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
