Excellent article and photos Matt.. I'm sure you're very proud!
Poster will be up on my wall very soon :thumbsup:
I've seen you blasting past Maccas a few times (the one just up from the freeway, trying not to go into too much detail here!) good to see the car being enjoyed!
great article in PI magazine!!!
Such an amazing car and the photos look brilliant!
Thanks guys. I have bought multiple copies to keep as momento. I am absolutely thrilled.
Cheers Matt
It was a white GTR Racepace special :) Nice work on the feature.
Hi Matt,
The looks hot in the Mag good work, i see your using a PFC Apexi how does the car drive?
Regards
Bobby
Thanks Bobby. The Power FC works well and car drives smoothly even with v Cam inetgrated with it. The idling is stable on Cold start. All other systems work well - air con; etc.
I am sure looking forward to a prominent magazine feature of your R34 build.
cheers
Matt
Deposit taken for ownership transfer.
Good luck to the pending new owner! I am confident that he will look after her as much as I have.
I have certainly taken a 'big' financial loss, but I still look at this entire build experience as being a gain and absolutely 'priceless', especially the friendships built over the years with fellow forum enthusiasts. I guess the finale was the feature in HPI.
A sincere thank you for all who have taken interest in this car.
(Apologies for all photos will be deleted to respect privacy of new owner)
Cheers
Matt
Well done on the build and feature. It's a shame it had to move on, but you just made someone very happy.
Hope they're on the forum and we can keep track of her progress, and lap times.
Edited by nick_7g
The owner is on here but there most likely won't be any lap times.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
