Thank you for your comments everyone! Its been great sharing my build with you!
Big Engine Update as we approach the finale of this build! I hope you like what you see - keep the comments coming
Built engine finds its rightful home in the engine bay! Engine bay has been repainted gloss white. The original factory matt off white colour looks too dull.
Main colour scheme is 'black and white Storm-Trooper' look.
Engine cam covers and oil catch can painted in crinkled black finish; all hoses and attachments are black as well. A few words that come to mind to describe the engine bay: 'mean'; 'industrial'; 'military' and 'stealth'.
Close up of crinkled paint finish. The paint is not uniformed in appearance and gives it a very unique look. It is different to the textured finish on say the Mines' signature purple or the Nismo S1; R1 red cam engine covers.
Note 'HKS Power' logo on the V cam cover - looks tough!
Detailed images of V Cam badge; V Cam solenoid, wiring and oil line input and HKS limited edition oil cap
Other supporting accessories:
Racepace custom Oil catch can and washer fluid combination, again in crinkled black finish. Hoses are neatly tucked away to be unobtrusive:
Racepace spec custom PWR based 50mm radiator:
Nismo Z Tune 100mm thick intercooler:
SARD 700cc injectors denoted by the light blue colour on the injector body:
Nismo Air intake duct:
Nismo aluminum piping:
I still have a few more surprises up my sleeve. (Hint - I am a wheel whore and the black and white Storm trooper theme...... :thumbsup: )
Thank you guys for feedback!
  Quote
Gts30t Posted Yesterday, 08:13 AM
Looks awesome matt, a nice strut bar would really finish off that bay
I planned to replace stock strut bar with Cusco Carbon fibre ALC40 when funds permit. Also planned Garage Defend Carbon radiator cooling panel.
  Quote
Aaron34 Posted Yesterday, 08:28 PM
beautiful job. No other way to describe it. Wow..
Now it needs to be shipped to Germany with mine and Snowmans to be truely enjoyed...
Pity I don't have the driving skills like you guys to make the most of it! :(
  Quote
BBGTR Posted Yesterday, 08:35 PM
I always like to see someone who is more anal than me when it comes to preparation.
Yes, I am super 'anal'. Believe it or not, I polish the rear bar after a every drive, because so much soot and fumes get blown out the rear end. As the car is white, if the fumes are left longer than a few days, the rear bumper; boot; spoiler supports and rear light cover goes yellow.
  Quote
bigmikespec Posted Today, 02:13 PM
Was there a decision made to keep the orginal plenum instead of going for a Nismo version?
I sold the Nismo plenum to another fellow member. Beno said that the Nismo plenum is good for mildly tuned RBs; but for RB28 its actually going to reduce output! He measured the inlet and the Nismo one is smaller in diameter compared to the stock item. The chamber of the Nismo carries more volume though and therefore beneficial for standard capacity RBs.
awesome car mate and great choice of bits. there is not anything I can really fault with it. it will be an absolute weapon to drive and should give years of fun. :P
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
