well. as youve noticed it seems i want a full work out on my GTR R33.
what would be the BEST turbo's to buy for it ? im talking for street racing / circuit racing. nothing Laggy please. i was thinking some 2530's ? or 2540R's? what else would i need to make this car 100% stable running at say 1.6Bar ? .
off the top of my head i will need:
Apexi Power FC
Cam Gears
Fuel Pump ( SIZE ??? )
Plenum ??
fuel injectors (size?? )
what is a good boost controler that i should buy ?
and a G-tech. hehe .
just remind me if i missed something out. or better ideas
https://www.sau.com.au/forums/topic/28776-best-streetcircuit-turbos/
A friend of mine made 310rwkw on 2530's in his R33GTR
you are on the right track the list should go like this
Apexi Power FC
Cam Gears
Fuel Pump ( Bosch motorsport 044 (by memory))
Twin plate clutch
fuel injectors (700cc)
Hks books controller, or you can get one attached to the Power FC, but i hear it is not as good (stand to be corrected)
2530's and full exhaust off the turbo's
Dont bother too much with the 2540 range if it is response you are after, while they are good, they are laggy.
dont bother with a single. They suck. A waste of time and money. If you are going to do 2530's a twin plate is an absolute minimum.
1.8 bar would not be out of the question on HKS 2530's but it would be at the higher end of their efficiency.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
