To cut a long story short i was being a dick and lost my licence for a year. I'm wondering if i should just leave the car sitting in the garage for a year or start it up and get someone to take it around the block once a week. Car is leaking coolant and clutch is nearly gone so i was thinking better to leave it sitting until i get my licence back and then get these things fixed up.
Any issues with letting it sit there for a year? Anything i should do before hand and after?
https://www.sau.com.au/forums/topic/287775-storage/
If the aircon still works, I would start it up at least every month and run the aircon for 5 mins so the seals don't dry out.
If it is going to sit, there for a year, before I would disconnect the battery. After; the oil will need to be changed, fuel tank drained (as the fuel will be long stale) and put fresh fuel in the tank
https://www.sau.com.au/forums/topic/287775-storage/#findComment-4823585
Before storing.
- Change oil
- Change coolant - most important
- Change brake fluid
- Give the car a good wash and wax
- Have around 1/4 to 1/2 tank of fuel - this will allow you to fill up with better fuel once you start driving again.
- Slightly over inflate the tires to prevent the tires from deforming - Check the pressures 1 a month.
- Start the car for around 15 minutes once every month - rev it up lightly during the last 5 minutes.
Hope this helps
https://www.sau.com.au/forums/topic/287775-storage/#findComment-4824561
Cool, the aircon works so i'll definately do that.
Before storing.
- Change oil
Hope this helps
Oil was changed 2,500km ago. Does it still need to be changed? The car is leaking coolant somewhere so is there any point changing it? Is it a corrosion thing?
I was just thinking of letting it sit there for the year and then change the coolant and oil once i start it up again. Bad idea?
https://www.sau.com.au/forums/topic/287775-storage/#findComment-4825170
Had my GTR sitting in the drive for over 9 months.
Just put new fuel in it, charged the battery and started it up. All was fine. Let it warm up at idle, then switched it off and changed the oil + filter.
Then, threw it on the dyno to check to see the fuel pump isn't nearly dead, etc.
Now she's good as gold.
GTR's have a plastic fuel tank, though. So I didn't need to worry about that rusting through.
I never pumped up the tyres, changed coolant, started it up, turned on the air-con, changed brake fluid, etc.
https://www.sau.com.au/forums/topic/287775-storage/#findComment-4826531
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
    • Looking forward to see if you can find something decent Duncan. I'm with Enthusiast. They seem happy enough to take my money but I have never claimed. I'm also also not convinced they would pay. Because, as per their PDS: I've ECU, exhaust, intake, intercooler, engine, turbo, fuel system, radiator, brakes, suspension and wheels listed on the insurance policy. But none of it is engineered or formally signed off. I presume that makes it not comply with ADRs. Because anything that might get defected goes against those rules, right?   Their other gotcha is parking on the street at home. Which is probably fine, but still.   Overall, + Can set salvage rights on the policy + Able to list modifications + Agreed value insurance - Question mark on whether they would pay a claim. The terms seem to hedge against it. - Only listed drivers on the policy are insured.   Overall I treat and drive the car like I am not insured.
    • Priced to move, at only $67k?
    • Not bad, thanks for sharing. I bought some black nismo floor mats, hopefully thats enough, im not a fan of the 90's jdm light grey!
    • You forgot just needs a battery and no test drive until full payment is made. 😆
