i guess the problem is that rotor boys for ages have criticised piston engines for not revving as well, when in fact what we've learnt here is that to compare rpm between piston and rotors is completely useless.
i understand and agree with most of what gary is saying, i think the problem here is we look too much at comparing the technical areas of 2 different machines that are only relevant to each type of machine. all we can do is look at the outputs in application really and compare that. the problem is that Mazda obviously tried to use these technical specs to market their engines over piston engines, which we now know was stupid to do so. so in that aspect, Mazda were deceiving.
Ok i appreciate you saying that. I have however read through this whole thread, thats why i decided to post.
For those of you who still doubt what i'm trying to say, have a look at this youtube vid:
This video explains it well, and is much easier than trying to explain with words in a post.
Does anyone still think there is a step up gear ratio between the rotors and eccentric shaft?
The stationary gear pinion and the ring gear on the rotor keep the rotor where it should be for the Wankel cycle, much like the cylinder bore keeps a piston where it should be. A Wankel needs this 3:1 (no other) ratio to operate properly just as a piston engine needs a bore.
Precisely, great post. A rotary is all about how it turns that movement into power, a relative motion. It therefore pumps 654cc x2 per shaft revolution (and fires accordingly), equivalent to a 1308cc 2 stroke or a 2616cc 4 stroke piston.
You can and in fact Mazda does. But is it correct to state that "a rotary engine does 9,000 rpm"? You will say, "well of course it is correct because the eccentric shaft does 9,000 rpm". Whereas I will say "no it isn't correct because the rotors are only doing 3,000 rpm". When we say "an engine does 9,000 rpm" the natural assumption is that all of the engine is doing 9,000 rpm". Now in a 2 stroke piston engine that is 100% correct, all of the engine is in fact doing 9,000 rpm. But in a rotary engine only the eccentric shaft is doing 9,000 rpm, nothing else. The rotors are only doing 3,000 rpm.
Keeping the above in mind, that means 100% of a 2 stroke piston engine is doing 9,000 rpm, but only 33% of a rotary engine is doing 9,000 rpm. In other words the vast majority of a rotary engine (ie; 67%) is only doing 3,000 rpm. So when someone says "a rotary engine does 9,000 rpm" I say rubbish because the whole engine is not doing 9,000 rpm. In fact I say double rubbish, because most of the engijne is only doing 3,000 rpm.
But wait, let me add even more weight to my argument. We are talking about an internal combustion engine here, so surely it is logical to count the rpm of the part that actualy carries out the combustion process. In a rotary engine that's the rotors and, like it or not, the fact is they are only doing 3,000 rpm.
This is usually the point at which the rotary huggers, start throwing in cycles not revolutions, orbits instead of rotations, no strokes in a rotary engine, elliptical motion, not up and down etc etc. But to me that's just being pedantic and deliberately narrowing the meaning of common use words, in some vane attempt to escape the truth. But the truth is right here, it's not out there.
Cheers
Gary
I think it makes perfect sense to measure rpms by the essentric shaft, just like pistons measure theirs by the crank. The e/shaft is the rotories equivalent of a crank shaft so the comparison is perfect. Who cares what is going on to make the shaft spin at that speed, it doesn't matter if its a windmill or a hampster on a bicycle - it should get measured where it counts. There is obviously just a difference in opinions on where rpms should be measured but lets face it, a rotor is not the same as a piston but both their primary objectives is to turn the driveshaft.
well said!
i understand what you are saying there, and mostly agree, however if a rotor fanboy came up to me and started going on about how a rotary is better because it could rev to 9000rpm and how many piston engines can do that? i would instantly revert to SK's point of view. the point is that they are different.
id reply back to them that my honda engine revs to that easily with all that vtec power!!! :)
edit: so does Tak's car on intial d, especially when he gets the new engine put in, it goes higher than 9000rpm :) .
i think what gary's trying to say is that mazda have effectively done this, they have used these "specs" to market their engine against piston engines. pretty sure this is gary's beef with mazda more than anything.
I don't think it's Mazda, I think it started with Felix Wankel himself, given NSU did the same thing with their rotaries.
Just tell him he's an absolute dumbass for even saying that an engine is better just because it revs higher. You need a defined variable for "better"...and engine rpm proves nothing. My air dremmel revs higher than 9000rpm...could it beat a car down the quartermile? Depends how long the air hose is and how fast you can run with it I guess.
LOL, exactly.
That page demonstrates the Wankel cycle perfectly. Everyone should look at that and observe that the power is coming from the "orbital" motion rather than the "rotational" motion, before they again say a Wankel only does 3000rpm.
Ok now that we have all learned that part, onto the capacity debate.
I would define "capacity" as the amount of air an engine would pump in one "cycle" of its operation. Would anyone disagree?
Now lets define "cycle".
I would call a cycle when something is in a initial state, does something, and returns to its initial state.
Wikipedia defines a "cycle" as: "...one complete occurrence of the event which repeats"
Nobody here is arguing that a 4-stroke engine takes 2 complete rotations of the output shaft to complete its cycle.
Nobody here is arguing that a 2-stroke engine takes 1 complete rotations of the output shaft to complete its cycle.
At the end of each cycle, both engines are doing exactly what they were doing at the start of their respective cycles.
At the end of a 4-stroke cycle of a 2L engine, the engine has pumped in 2L and pumped out 2L.
At the end of a 2-stroke cycle of a 1L engine, the engine has pumped in 1L and pumped out 1L.
No arguments there?
Now lets play spot the difference (courtesy of RICE RACING)
In both of these pictures, the top left chamber has almost finished inletting, the bottom left chamber is about to exhaust and the right chamber has compressed the air/fuel, waiting for a spark (or two).
In terms of combustion, both of those pictures are in the same state, however they are one output shaft ratation away from each other.
After a 13b Wankel has completed 1 full rotation of the output shaft, the engine has pumped in 1.3L and pumped out 1.3L.
In 3 full rotations of the output shaft, it will have done this cycle 3 times.
Hopefully this has explained my point of view.
I'll be interested to see how people will debate this. Please back your arguments up with evidence.
No arguments there?
With every combustion the output shaft completes one cycle. SK has been trippling his numbers because it takes 3.9l of air for the first side of the rotor to return to its origional position (the other 2 sides following afterwards). If we measure the cycles by full turns of the e/shaft then 1.3l is correct.
No evidence required, you have already supplied enough in your post for me to prove that I'm correct. At this point I suggest you go back and actually read what you posted. Since you reused Rice's diagrams, I'm surprised that you didn't realise why he stopped the debate, his diagram confirmed my opinion.
It's actually quite simple, you measure capacity by eccentric shaft revolutions. I measure capacity by revolutions (oribits if you prefer) of the pumping medium, ie; the rotors. In one revolution (orbit if you prefer) of the 2 rotors a 13B pumps 3.9 litres.
So I define a cycle of a rotary engine as one complete revolution (orbit if you prefer) of the rotor. You on the other hand define a cycle of a rotary engine as one complete revolution of the eccentric shaft.
So who is right?
Well I base my argument on the fact that a 4 stroke 2 litre engine is always called a 2 litre even though it only pumps 1 litre for one complete cycle (revolution if you prefer) of its crankshaft.
In simple terms we don't dived a 4 strokes piston engine's capacity by 2, so why should we dived a rotary engine's capacity by 3?
Cheers
Gary
Has the "cycle" of an engine got to do with the combustion cycle or where things are in the engine?
If it was just about where things are in the engine, a 4-stroke piston cycle would only be one rotation of the shaft.
Wouldn't work very well though.
I do see your point, but i don't think the fact that it takes 3 combustion cycles for the rotor to do a complete rotation is somewhat irrelevant.
Now we're getting somewhere. We are beginning to understand the relative time scale - how the combustion is applied and ends in power and subsqeuently how it all relates for this unique engine. This is the only correct way to understand the it, considering the whole unit. Well done fellas. :)
... I'm correct.
Cheers
Gary
LOL
Get your hand off it mate. RICE Racing is miles ahead of you. I posted the link from 2008 where he cut up a rotor to educate people on its cycle. He's been saying all this stuff since the early 1990s. The thing is he understand relative time scale, considering the engiune as a whole unit, which you do not. He gave up arguing as you merely assume you are correct.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
