well now we all agree that the RX-7 sucks due to the Mazda lies since it is a 3.9l rotary cycle motor with characteristics of both 2 and 4 stroke piston engines!
i disagree, i believe it's the turbo hanging off the side of the engine which makes it suck.
Some folk think you can..
http://mikesdriveway.com/misc/rotor.doc
that explains things very well and sums things up quite nicely I think.
personally though I still don't give a crap. engine size is not important to me. I have owned vehicles from .13cc to 4.2L and some small engines were better than some bigger ones and vice versa. there are so many factors that go into a good engine package, materials, quality of manufacture, ancillaries (turbo? super charger? NA?), and the list goes on.
annnnnnnd...... end scene.. start the music... roll the credits... fade to black.. and cut. thats a wrap everyone, great job, dont forget to drop your security cards to nancy on the way out... come on people we need to be out of here by 5pm, they are shooting the next "egg or chicken" debate in here.
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
    • Umm.... He attached it to his 2021 update post. Don't need the link. It is stored on the forum.
