hey guys just bought my first skyline after waiting so long. the car is amazing and i can see why there a much love car.
let me no wat you guys think specs are as follows
Mods
- Legally mounted AAA Racing Air filter with aluminium induction hard pipe
- Brand new extreme heavy duty clutch
- 3 inch one piece front end dump pipe
- 3inch Straight through exhaust
- Nolathane front bushes
- Aftermarket Japanese racing shocks
- Tein springs
- All 4 upgraded R33 rotors (front slotted)
- Adjustable upper rear camber arms
- Drift Magnetic oil filter
- Oil Catch Can
Exterior
- Custom Gun Metal Grey with prismatic
- GTR front bar (n1 air inductions)
- Aftermarket smoked crystal taillights
- Front 20mm wide body guards with vents
- Rolled guards
- Spoiler has been removed
- Crystal vision parkers
- Carbon window wipers
- Geniune Nissan clear indecators
Interior
- Speco Boost gauge legally/neatly mounted with blue light
- Custom made Gear and Handbrake boot
- AIR CON WORKS
- Blue neon's under foot well
- Cyclops Alarm with remote central locking
- Nismo gear knob
- Sound system (etc Deck, Speakers, Splits
the car is completly imaculate the credit has to go to the previous owner who performd alot of work on the car to get it to this state,
future mods :
- gtr fmi
- gtr injectors
- gtr or boshc fuel pump
- boost controller
- tossing up between r33 high flowed turbo or a hks gtss turbo i think it is
- also want to get sum more suspension work done as power is not every thing
hope fully that will see me to the 190 - 200 rwk range as i dont wait to chase to much power because i am going to start building a 25/30 in the near futurelet me no wat you guys think
https://www.sau.com.au/forums/topic/287791-my-new-skyline/
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
