Hi everyone,
As topic states Is it worth putting R34 GTR turbos on R32 GTR?
I know they are steel wheel , ball bearing turbos so thats a plus. You could also run a bit more boost than 1 bar as well right?
Anyone done this before?
R34 GTR turbos are not steel wheeled.
They are cermic - it is not worth it.
Plenty of people have had them fail, just like all other factory GTR turbos. GTRGeoff in QLD had a low km set fail @ ~1bar as one example - killed the motor.
You play the game of chance @ your own risk.
The R34 N1 turbos are the pick of the litter when it comes to lag of N1 turbos, but I hope you do mean mean R34 N1 turbos not R34 GTR turbos as the R34 GTR are ceramic wheel, except for the R34 GTR N1 and Nur spec which come with the N1 steel wheel turbos
however the stock turbochargers in the BNR34 are larger, the compressor is 0.53a/r vs 0.42a/r (BNR32 and BCNR33)
but the ceramic issue/risk still remains in all family turbochargers
ok i guess what the dude means is swapping the
r32 gtr gt25 turbos
for the
r34 gtr gt28 turbos
if its for a lil tweak it should work but if its for big power you should updrade to a bigger set from garrett or sum
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
