right so basically my car (skyline r33 n/a) isnt running properly i suspect it is a fuel issue with either the
fuel pump, fuel lines or the injectors. what it is doing is kind of like a miss but it will happen even when im not accelerating
and at times the car will cut out completly, i can even start the car and it will run fine for about 10 seconds and then it will
cut out.
anyone ever had this problem or can give us some advice on how to fix the problem would be appreciated, cheers.
https://www.sau.com.au/forums/topic/287800-suspected-fuel-issues/
10 year old car, most likely the pump. Cheapest option is the Walbro pump (check the forum sponsor Sliding Performance, $155 delivered), or go with a Bosch 040, DIY guide for the 040 install is here: http://www.skylinesaustralia.com/forums/To...mp-t253097.html
