slide_it Posted September 13, 2009 Share Posted September 13, 2009 right so basically my car (skyline r33 n/a) isnt running properly i suspect it is a fuel issue with either the fuel pump, fuel lines or the injectors. what it is doing is kind of like a miss but it will happen even when im not accelerating and at times the car will cut out completly, i can even start the car and it will run fine for about 10 seconds and then it will cut out. anyone ever had this problem or can give us some advice on how to fix the problem would be appreciated, cheers. Link to comment https://www.sau.com.au/forums/topic/287803-suspected-fuel-issues/ Share on other sites More sharing options...
gotRICE? Posted September 16, 2009 Share Posted September 16, 2009 Id try a set of coilpacks before ripping into fuel pumps/injectors. See if you can borrow a known working set. Link to comment https://www.sau.com.au/forums/topic/287803-suspected-fuel-issues/#findComment-4829348 Share on other sites More sharing options...
momentum_gtr Posted September 25, 2009 Share Posted September 25, 2009 right so basically my car (skyline r33 n/a) isnt running properly i suspect it is a fuel issue with either thefuel pump, fuel lines or the injectors. what it is doing is kind of like a miss but it will happen even when im not accelerating and at times the car will cut out completly, i can even start the car and it will run fine for about 10 seconds and then it will cut out. anyone ever had this problem or can give us some advice on how to fix the problem would be appreciated, cheers. i have just fixed a similar problem on my uncles r33 gts-t by changing afm if this helps?? Link to comment https://www.sau.com.au/forums/topic/287803-suspected-fuel-issues/#findComment-4847192 Share on other sites More sharing options...
Tadahisa Posted September 26, 2009 Share Posted September 26, 2009 (edited) I've had a similar problem where my 33 kept experiencing fuel cuts then eventually it wouldn't start. Took it in and turned out to be clogged fuel pump cost me a bomb to replace!!! D: Edited September 26, 2009 by Tadahisa Link to comment https://www.sau.com.au/forums/topic/287803-suspected-fuel-issues/#findComment-4848696 Share on other sites More sharing options...
08r3308 Posted September 28, 2009 Share Posted September 28, 2009 check coilpacks and spark plugs like its been suggested Link to comment https://www.sau.com.au/forums/topic/287803-suspected-fuel-issues/#findComment-4851366 Share on other sites More sharing options...
