First of all hi to everyone on this forum. In the process of looking for an R32 GTR and feel like pulling my hair out so am after a little advice. I have 20k budget to spend. I've spent the last month making phone calls and looking at cars and really can't decide what to buy. Most of what I've seen so far has been a bit dissapointing or maybe my expectations are too high. I've looked at cars that have a modification list as long as your arm but quite frankly I think have been quite shabby in condition on bodywork and interior. Although I have seen one car that is well below my budget with fairly good bodywork and interior but is in fairly standard form. Would it be easier for me to buy a pretty standard car at a cheap price and then mod it myself or am I better off getting one thats had a shed load of money spent on it and sacrifice the aesthetics. Any help much appreciated.
https://www.sau.com.au/forums/topic/287820-which-car/
On the contrary, keep your expectations high, and the right car will come along.
Check out the Top Secret Imports website here at Blacktown NSW. They've had some R32 GT-Rs stock with low Kms and no rust.
Ask what Kristian has at Iron Chef Imports in SA too.
They won't let you down...
https://www.sau.com.au/forums/topic/287820-which-car/#findComment-4837766
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
