You can buy FM transmitters which connect to your iPod and play the audio on an FM frequency which you tune your car's radio into. There is another variant which allows the iPod to be played directly through the tape deck.
Has anyone tried either of these options, and if you have, which one and was the audio quality any good??
Well i've tried both before i ended up changing the whole system to a double din setup. I have to say both offer mediocre quality audio if you're the fussy type.
But i guess it's the cheapest way to do it :)
I think i read up somewhere on G35Driver Forums about the adapter called PA11-NIS to hook up the ipod to the factory stereo. But i don't know if it'll work here.
Wait and see what Chris Rogers have to say about this.
tiger,
easier way is to buy a AUX in lead and run it up to your centre console. the FM idea is really a waste of $$. stations will come in ovr the top of the ipod, dropouts and terrible sound.
call me if you do not follow :P
I've used both in my Z33. It was a stopgap solution when the stock head unit's CD player died, before I got a new deck.
The audio quality is shit (although that shouldn't bother you if you're still using the supplied iPod headphones) in either option. Through the tape deck you get massive amounts of hiss. Output via the FM adapter sounds muted, and since the signal power is so weak any little thing interferes with the signal.
Also, fiddling around changing the tracks will probably get you accused of using a mobile phone while driving if you're spotted, and the cops will probably book you despite any protestations.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
