Hi, my engine light came on last Saturday- thought could have Been a meter misread cause of the change in weather because it turned off when I restarted the car. 15 mins later it came back and unfrtunately hasn't left since.
Not feeling a difference in performance nor realising misfires. Oil levels fine so is coolant- car temp is always normal.
Called closest Nissan dealer to do a check as to what the issue is, they don't deal with r34 (even though it is still a Nissan) I live in sydneys inner west so if anyone knows a place to take it too that would be great or if anyone knows the issue that too would be appreciated
cheers
https://www.sau.com.au/forums/topic/287858-r34-25gt-engine-light/
It'll most likely be the coilpacks, if the stock ones are still in there. Extremely common prob.
It will seem fine for a couple of weeks, then you'll notice a misfire and it'll get worse from there.
Get yourself a consult cable from here and you can confirm what the fault is. Fault code 21 = will be coilpacks. If you took it a dealership or mechanic, this is what they'd basically do - plug it in and see what fault code is on the computer.
There is another way to check by bridging the pins on the consult port (just search on here).
I got JJR ones for $399 delivered, and put new plugs in as well.
+1
i had the exact same problem, just a little light coming on once and a while, also thought it was just cos of damp weather, no noticable misfire at first either (stock exhaust does a good job of hiding the misfire)...took almost 2 years of slowly getting worse before it got very bad and car was nearly undriveable , , , bit the bullet and replaced all of my coils (and plugs just cos they were overdue) and the car has never been better since - turned out all 6 of my coils were infact blown
but there are also some interesting discussion that OEM replacement coils are better then aftermarket, (i replaced mine with aftermarket cos is cheaper) most people dog on the r34 coils really bad, but to be honest im pretty impressed that the OEM coils withstood almost 12 years of engine heat before packing in, ill be happy if my aftermarket ones last half that long!
The R34 factory coilpacks are fine to use in your engine, however new coilpacks are up around the $1200 mark new from Nissan.
JJR $399
Splitfire $499~
Nissan OEM $1200
So why would you buy Nissan ones :P and dont just buy 2nd hand "working" replacements, theyll only suffer the same fate of the last ones, if you put brand new coils in, they will last much longer.
  • 1 year later...
hi my car also has that idle problem but its only just starting to do it ie once every 2 weeks
would a mechanic be able to detect the problem even if its not misfiring "at the time its getting serviced"
because my dad doesnt want me to jump to conclusions buying a new set of coilpacks and wants me to take it to nissan or nismo in thomastown :(
cheers :D
and would new coils at any performance because unfortunatly im on my p's so performance hungry lol XD
  • 3 weeks later...
  • 10 months later...
Ughhhh! I've had this problem for a while now.
Basically I had a faulty coil, then another one.. I have changed the coils (all of them) to Yellow jackets.
Still having problems.. What else could it be?! Coil loom? what else is there that could be causing it? Injectors?
P.S I've changed the spark plugs..
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
