Hello there, I have a problem.
The wires that connect to the neutral and reverse switch in the gearbox of my R32GTS4 (same and an R32GTR) are missing. This means that my reverse lights don't come on when I am reversing which is an issue fo rego. I can't really see where the wires are meant to go; though I am guessing that they join the engine loom somewhere around the alternator. I need help can anyone
a. confirm where these wires connect to the loom
b. confirm which wires in the loom connect to which wires on the switches
Thanks, Ben 0411 243 284.
Dude i Have the same problem , ever since i got my clutch replaced i have had not reverse lights, Could you please post up a pic so i can see where the wires run from to the switch so i can fix mine, this would be awesome if you could help.
Hi Zardo, I have attached a picture from the R32GTR workshop manual with the reverse switch circled. I am guessing that they have forgotten to plug yours in properly when they put the gearbox back. I can't tell you exactly where the wires are going because that is my question. I think my wires got caught up on my front driveshaft and got pulled out. I have the switches, but don't know where they are going. If you get under your car to check that your switches are plugged in, maybe you could take a look at where the wires are going and what colour wires plug into your reverse switch?
This picture is pretty self explanitory after you have taken a look under your car. Essentially the neutral and reverse switches are located near the top of the driver's side of your gear box. If you get under the car and locate the front drive shift coming from the gearbox you will notice that these are just above there - quite difficult to get your hands to!
Edited by Birth
Thanks. Also, if its possible while you are down there; can you please tell me what colour wires on the car side of the connectors are plugging into the a. neutral switch and b. revese switch (or a. the switch on the rear side of the car and b. switch on the front side of the car)? It woudl be a massive help as I have nothing at all there!
These are the wires that I have hanging out which I assume are for the neutral and reverse switches. Can anyone confirm that these should be them. Not that this picture is of the driver's side of the engine under the plenum, you can see the alsternator in the back.
  • 3 years later...
Iv got the same problem with my 32 gtr atm. it isnt missing the wiring it just got no reverse lights.
we have the box out atm as we are replacing the clutch and i was going to try and rectify the issue. i , if i remember, can have a look under thae car when we get back to it this weekend and suss out the colour of the wiring etc if ya want.
i havent really looked at them at this point. do you know if they are just screw in plugs or anything??
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
