Hi all,
I have a strange problem... my R33 GTST (stock as a rock) wont start, it wont even engage the starter motor. one day it was cranking to start, then the next time i tried... NOTHING, further to this my reds on my dash come up as usual if you are turing your car on but I can pull the key back out and they all stay on.
the only way to get the reds OFF is to pull the battery out.
I do NOT have an immobiliser on the car yet so it's not that besides which they stay on permenantly anyway...
I just got the car, it had the engine replaced but wasn't finished being put together yet so I finished it up, all that needed to happen was to have the possitives connected to the front relay box. Anyway as stated above, it was cranking it just didn't have enough power left in the battery to kick it over properly... I replaced teh battery and now I have this problem.
My Auto elec friend checked it out and thought it might have been the ECU, so I have replaced that and the ploblem still exists.
Has anyone seen this before or does anyone have any ideas? I'm completely lost on this one :P
Any help would be greatly appreciated.
Thanks,
H
https://www.sau.com.au/forums/topic/287878-car-wont-start-reds-stay-on-help/
yes there is one there, but I have pulled it out,.. just unplugged it from the loom.
But how would that explain the fact that it was working before? have tried plugging it in and taking it out a few times, but no joy...
any other thoughts anyone at all?
An air gap?
How on earth? are you suggesting there is an air line that is supposed to be plugged in? I ask this feeling a little sheepish because that seems a little strange... I have installed a few of these (pure electrical)... eitherway, I will have a look at the relay it's plugged into to see if there is a problem there.
Although I have unplugged these before aswell for rego purposes... never had the problem.
Still not sure what else to try.
Airgap = two electrical contacts that don't touch
You have a live ignition wire going into the turbo timer and then it comes back out again and carries on to the loom. If you unplug the timer you should have open circuit.
A turbo timer is just a fancy on/off switch, if you take the switch out then you have no current flow. So unless you bridge the two appropriate wires ie join them up using a link wire then you have an airgap.
Ahh, understood, I thought for a moment you were talking about an air line...
all the same, i will go remove the timer from the system altogether and see if that helps (connecting all wires to factory state).
Would that explain why the reds are staying on?
we also have the problem of the starter not engaging... with previous turbo timers I have been able to engage the starter even when the timer was on and doing it's thing regardlss of whether the car is running at the time.
Anyone got any thoughts on this ?
Thanks for your help so far Trident, really appreciate the input.
It sounds like it'd be the timer, or at very least be something to do with the wires going to the timer/ignition etc. Make sure you haven't pulled something out/loose with all the fiddling, if you get me.
It's manual.
Also I had my auto electritian coem round last night...
he removed the turbo timer wiring completely, problem still existed. He then pulled all the blugs out of the ignition and probed them, we could get the lights to go off by effetively earthing out a wire... that wire went to the starter motor, so we disconnected the starter... the problem still existed BUT the lights would go out if we earthed a DIFFERENT wire this time...
It's all very strange particularly because the problem didn't exist a week ago and has popped up .
so in summary, the car is now 100% stock, no timer, controller or anything else.
The problem is still there, no starter engage, red's won't go out... there is NO alarm or immobiliser on this car.
Going to have to go to the wiring diagram on this one, but not being as technical as some I have no idea what we will find...
any other ideas would be great in the mean time guys.
cheers.
will try putting into diagnostic mode tonight...
we pulled all the plugs in the bastard out and still the problem exists... anyone think of anything new?
I will update with anything the ecu fesses up tonight.
cheers for the idea. now all I need to do is figure out HOW to put it into dig mode... also whether I will actually be ABLE to if it involves using the ignition... cause it doesn't turn off.
No alarm... no immobilizer, no turbo timer.
She is totally stock now with NOTHING aftermarket, and no original immobilizer or anything like that... I don't think they ever had them factory anyhow ;)
My electrician thinks that perhaps there is a bad earth somewhere in the car, but I just don't know what could cause this, we have looked at all the wiring we can, all the earths, nothing.
Any other ideas? Happy to go over what I have already done.
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
    • I bought my Bride reps from Crank Motorsport. He is, um, a trifle disorganised. I would have to look back at the e-mails to make sure I got it right, but I think he sent me normal fabric ones when I ordered the "Alcantara" ones. So he had to pay for shipping 3x and I'm sure that f**ked him off big time. And asking technical questions where nuanced English is required is a no go. It's simple English only. And....should I have bought the Alcantara ones? Well, as it turns out, they are great, feel great, etc, but the fabris wore through on the point of the waist bolster in <2 years. Must have caught a rip from a rivet on jeans or shorts, or something like that. So now I have to patch it somehow. A bit shit. My fault, ultimately, because it is Chinesium Faux Alcantara, not the real thing, and it turns ot that it has the tear resistance of a soggy tissue. But the seats and the reails are great. I probably should have gotten the R34 style ones, and now that they price is up in that ridiculous sort of number, I could have sold them for a profit!
    • Another recco is to just let it rest for a while and go back and reconnect later.
    • keep an extinguisher nearby? or even better, take it out of the car to charge?
