well that blew away my autowatch alarm theory.. have you checked all the relays in the box near the battery? sometimes they can go and there is no way to tell just looking at them.. take them out of a mates car and replace them etc.. see how that idea goes
  • 1 month later...
I had a little problem like this before, does a little red light come on next to the battery and check oil light come on, if it comes on check a fuse under your dash, this happened to me and couldn't start my car i don't have a alarm or immobiliser but the people before me put one in, so you might not think you have one but someone might of put a after market one in and took it out when sold, Good luck
i had this problem before.
first thing i did was to wiggle around the steering and turn the ignition to see if it would start. This method DID NOT work.
the second i got a wiring diagram and went through all the earthing points on my car (r32gts) and basically replaced them or screw them properly. This FIXED the problem, but it might be different for you.
so if it is an electrical problem just check your earthing first and go from there.
hey mate dunno if this helps but from what you explained I had the same problem last week, I was stuck on the side of the road and my car wouldnt engage the starter motor, I still had reds and power and thought it had to be my alarm or turbo timer, after disabling the imobilizer and turbo timer same issue, then after alot of tearing my hair out and frustration I decided to just pull the battery out walk down to the petrol station and get another one, put it in and started first go, havnt had any dramas since ... looks like I had a dead cell in the battery or something, but it was strange coz a few quick checks with a multimeter didnt show anything still had 12.4 volts in it and an acid leak test didnt show anything either, if u can get ur hands on a battery outta another car or somethin try it ? hope this helps
Hey all,
Thanks very much for all the input, the car is fixed and going now, it was an earth in the front fuse box... Amazing, it WAS earthed with another earth but wasn't getting a good enough connection obviously.... really strange.
The car would start if jumped from the front, but couldn't run off the battery at the back, thats how we narrowed down on where the problem would be.
Anyway, just have to put the interior back together now and life will be merry...
thanks again everyone :P!!
  • 8 years later...
Sorry to bring this up I had the exact same problem tonight just as I ripped out the turbo timer in a Woolworths carpark lol I found it to be an earth in the engine bay had the exact same symptoms hope this helps anyone later.
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
