Hey guys, due to a front end update, I am selling my existing stuff.
Would like them to go all at once.
Ideally it will be pickup, but I can ship at additional cost if you need me to :P
Factory Xenon's. All globes included - 4300k D2R xenon, H4 high beam, SMD LED parkers (white) and yellow indicator globes.
The lights do need the rear cover and indicator globe plug (Nissan part #26243-AQ000)
NM35 front bar and grill
Will obviously be cleaned before handing over/shipping.
There are some light surface scratches but generally in pretty good condition.
The rubber lip is in good condition with no broken tabs.
The grill also is in good nick with no broken tabs.
$450 the lot.
Edited by iamhe77
https://www.sau.com.au/forums/topic/287879-m35-stagea-front-bar-grill-xenons/
  • 1 month later...
Just out of interest, do you have any pics of the new front end your changing to ??
Yes.
I originally bought this PM35 RX front bar
But I will be looking to move it on as well due to me buying an Autech Axis S front bar (in my avatar)
Yes.
id be keen on this.. :( what's the move it on price ??
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
Hi
What type of new front did you install, did you have to export it or did you buy the new front here in Aus
im looking to do some upgrades, and im looking at all the options. my brother is in japan and heres getting me the prices of the nismo badges from nissan
thanks bryan
Hi
thanks bryan
Hi Bryan,
I purchased an Axis S front bar and a 2006 M35 bonnet via Import Monster to continue my conversion (I still need a grill :no: )
It will not fit on an ARX or normal Axis due to their flares.... although they can be removed.
Here is how it looked before I meshed the lower intake spacers (black mesh of course) which made it look much, much, much better.
Edited by iamhe77
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
