Hey guys, due to a front end update, I am selling my existing stuff.
Would like them to go all at once.
Ideally it will be pickup, but I can ship at additional cost if you need me to :P
Factory Xenon's. All globes included - 4300k D2R xenon, H4 high beam, SMD LED parkers (white) and yellow indicator globes.
The lights do need the rear cover and indicator globe plug (Nissan part #26243-AQ000)
NM35 front bar and grill
Will obviously be cleaned before handing over/shipping.
There are some light surface scratches but generally in pretty good condition.
The rubber lip is in good condition with no broken tabs.
The grill also is in good nick with no broken tabs.
$450 the lot.
Edited by iamhe77
https://www.sau.com.au/forums/topic/287879-m35-stagea-front-bar-grill-xenons/
  • 1 month later...
Just out of interest, do you have any pics of the new front end your changing to ??
Yes.
I originally bought this PM35 RX front bar
But I will be looking to move it on as well due to me buying an Autech Axis S front bar (in my avatar)
Yes.
id be keen on this.. :( what's the move it on price ??
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
Hi
What type of new front did you install, did you have to export it or did you buy the new front here in Aus
im looking to do some upgrades, and im looking at all the options. my brother is in japan and heres getting me the prices of the nismo badges from nissan
thanks bryan
Hi
thanks bryan
Hi Bryan,
I purchased an Axis S front bar and a 2006 M35 bonnet via Import Monster to continue my conversion (I still need a grill :no: )
It will not fit on an ARX or normal Axis due to their flares.... although they can be removed.
Here is how it looked before I meshed the lower intake spacers (black mesh of course) which made it look much, much, much better.
Edited by iamhe77
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
