Posting on behalf of my mate who dont have internet.
1992 GTR R32 with genuine 108,000k
he bought the car 2007 jan with 92,000k's on it, he was the first owner in aus and imported it.
Cars is very clean he is a clean freak and will wash it twice a week and polish it every 2nd week. drives me nuts everytime i rock up he is washing it or polishing it.
Mods on the car are
-apexi suction kit
-mines ecu
-highflowed r33 gtr turbos (i fitted them 2 months ago)
-3.5" front pipe
-decat pipe (has std cat)
-3.5" cat back (has new good standard exhaust he got one made as he got defected a month ago)
-cusco front strut brace
-tein front suspension and kyb rear
-camber/caster front and rear adjustable not sure on brands
-jjr red silicon cooler hoses
-defi gauges boost and water on pillar mount
-greedy turbo timer
-hks timing belt (i replaced 3 months ago)
-Rays 18x10 rims rare rims!
car is in top condition and always driven like a granny most mods come on the car when he got it, the turbos we put on because the std ones dropped a wheel, silicon intercooler hoses we put on because the std old ones cracked, apexi suction kit and mins ecu where put on when he bought the car.
Fuel pump died aus day this year and i put in a 255lph pump cant remember brand.
also i done a compression test when i replaced turbos cant remember the readings but they where all good can test again if intrested.
he is selling because he has lost the passion for the gtr and has bought a house.
um lets see been trying to get him to get a boost controler and get it on the dyno and liven the thing up abit with some boost but he just insnt intrested.
he wants a honaa dc2 intega or something cheap to run and sporty so intrested in swaps and cash his way.
so $21,500 ono
car is located in Mount Gambier SA
Ash : 0423913197
haha this is when the fuel pump gave up aus day this year, full of beer it lead to.
Will get some off him tonight any points you want to see or just general? also will have engine bay up tonight aswell.
can u post up some interior pics
Price is high because its in perfect condition and the wheels are worth alot, without wheels $18,500 and 17" wheels will be supplied.
has 3 bubbles in dash as you can see in picture which is standard for the r32's, seats and rest of interiour perfect.
has alpine headunit with ipod connectivity.
nismo gearknob
car just passed a majior defect went over the pits and passed first shot. things that where changed was exhaust, wheels the track is to wide, gauges and turbo timer removed. (these item have been put back on and come with the sale items can removed and price deducted)
Also has had a new powersteering rack put in 2 months ago.
very clean cant stress this enough this is a un raped r32 gtr veryhard to find decent ones these days.
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
