Posting on behalf of my mate who dont have internet.
1992 GTR R32 with genuine 108,000k
he bought the car 2007 jan with 92,000k's on it, he was the first owner in aus and imported it.
Cars is very clean he is a clean freak and will wash it twice a week and polish it every 2nd week. drives me nuts everytime i rock up he is washing it or polishing it.
Mods on the car are
-apexi suction kit
-mines ecu
-highflowed r33 gtr turbos (i fitted them 2 months ago)
-3.5" front pipe
-decat pipe (has std cat)
-3.5" cat back (has new good standard exhaust he got one made as he got defected a month ago)
-cusco front strut brace
-tein front suspension and kyb rear
-camber/caster front and rear adjustable not sure on brands
-jjr red silicon cooler hoses
-defi gauges boost and water on pillar mount
-greedy turbo timer
-hks timing belt (i replaced 3 months ago)
-Rays 18x10 rims rare rims!
car is in top condition and always driven like a granny most mods come on the car when he got it, the turbos we put on because the std ones dropped a wheel, silicon intercooler hoses we put on because the std old ones cracked, apexi suction kit and mins ecu where put on when he bought the car.
Fuel pump died aus day this year and i put in a 255lph pump cant remember brand.
also i done a compression test when i replaced turbos cant remember the readings but they where all good can test again if intrested.
he is selling because he has lost the passion for the gtr and has bought a house.
um lets see been trying to get him to get a boost controler and get it on the dyno and liven the thing up abit with some boost but he just insnt intrested.
he wants a honaa dc2 intega or something cheap to run and sporty so intrested in swaps and cash his way.
so $21,500 ono
car is located in Mount Gambier SA
Ash : 0423913197
haha this is when the fuel pump gave up aus day this year, full of beer it lead to.
Will get some off him tonight any points you want to see or just general? also will have engine bay up tonight aswell.
  Grk_R33 said:
can u post up some interior pics
Price is high because its in perfect condition and the wheels are worth alot, without wheels $18,500 and 17" wheels will be supplied.
has 3 bubbles in dash as you can see in picture which is standard for the r32's, seats and rest of interiour perfect.
has alpine headunit with ipod connectivity.
nismo gearknob
car just passed a majior defect went over the pits and passed first shot. things that where changed was exhaust, wheels the track is to wide, gauges and turbo timer removed. (these item have been put back on and come with the sale items can removed and price deducted)
Also has had a new powersteering rack put in 2 months ago.
very clean cant stress this enough this is a un raped r32 gtr veryhard to find decent ones these days.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
