Since ACT rego seem to want to stuff me around, anyone on here able to confirm how much bigger profile tyres I can run vs standard? Ie is my cars came with 205/35 front tyres can I run 235/45 or whatever?
Also what about diameter of tyres?
https://www.sau.com.au/forums/topic/287887-profile-tyres-and-act-rego/
CeJay, I cannot confirm with the R32, but my rim/tyre combo are engineered and passed through dickson. 235/40 front and 265/35 rear. (Std for R33 I was pretty sure are 205/55 or something like that)
The diameter of the tyre doesn't matter as long as you don't modify the rolling diameter (much). Which is tested with the GPS by the engineer against your speedo.
well ended up giving canberra connect a call and they ended up saying the following.:
Rolling diameter can't go up more than 15mm.
Track can't go up more than 25 mm etc.
Just need to check if my "235/45" profile tyres will be withing 15mm of the standard r32 profiles.
i assume you meant 205/55??
diameter of the tyre depends on the size of the wheel (ie 16 or 17 inch + the side wall of the tyre) the standard r32 wheel is a 16inch.. so are you running your 235/45 on a 16 or a 17 inch wheel?
235/45R16 is 7mm smaller (rolling diameter) than a 205/55R16
however a 235/45R17 is 18.4mm bigger (rolling diameter) than a 205/55R16
This is all assuming that the tyres arent stretched too much over the rims
Track is all to do with the offset of the wheel as compared to stock so i got NFI on that front.. i think stock r32 (non GTR) offset is around +40
why dont you just borrow someones stock wheels to get your car over the pits?
Edited by nerm
I'm running it on 17 inch rims at this stage I'll probably just be swapping my 235/45 profile tyres onto my 7.5 inch wide 17' ROH rims. Will confirm the tyre placard tonight as i think they were slightly different front to rear. Otherwise I'll get other rims.
japs tend to have different sizes front and rear. my car comes stock with 205/55R16 Front and 225/50R16 on the rear.
im currently running 235/45R18 front and 265/30R18 rear. Strangly enough 265/30R18 is only 17mm bigger than 225/50R16 on paper but it actually comes at about 14mm because the tyre is streched
Chris this is all about the overall diamater of the rim and tyre combination and is best explained by the attached Toyo tyre chart.
The standard Skyline tyre size is 205/55R16 and has a diamater of 634mm and this means that any tyres that are between 619mm and 649mm are legal on your car.
Some common tyre sizes that guys run are:
235/45ZR17 644
255/40ZR17 636
235/40ZR18 644
265/35ZR18 644
The other interesting point is to try and find common sizes that are sold in larger numbers as the unit cost will be lower (eg on my R33GTS-T I run 245/40ZR18 on the front and 265/35ZR18 on the rear and the 265 are about $40 cheaper per tyre).
Toyo_Proxes_4.pdf
the 634mm will change depending on the width of the rim and the stretch of the tyre. what is the width of the rim that that measurement was taken from?
well looks like my tyres might just scrape in
r32 runs 205/55 R16s on the front
225/50 R16's on the back
or 631.90 and 631.40
235/45 R17 rims are 643.30 mm rolling diameter
http://www.sr20tuning.com/tyresize.html
and yeah I've finally got my tyre placard, thanks for the help though
  • 3 weeks later...
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
