Originally posted by GTR-80Y
i have also heard that to properly reset the ECU you need a proper diagnostic tool.
The proper diagnostic tool is a wire paper clip
The R33 method is to open the fuse pannel under the dash
you will see a grey connector pointing downwards, pick the two wires on their own in the plug (the ones closesed to you) turn on the ign put the paper clip in so it shorts the two wires for around two seconds (this puts the ecu in diag mode) remove paper clip.
the chk eng light on the dash will start flashing a set of codes turn the ign off & on again the ecu is now reset
benifits: no reprograming the radio or clock & no spanners sparking on the rear of the parcel shelf (killing the ecu's).
Regards DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-50792
Regards DAMQIK
That sounds _very_ dodgey although it's probably right. I've been told that the ECU has a built in battery (button type) that even after disconnecting the battery will retain the ECU setup. So the only way is to flatten/remove that button battery or to short the ECU as described above. DAMQIK can you explain what the wires are and how it works?
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-50798
Yes, one wire is an earth and the other a signal (to put the ecu in diags mode)
it dose the same as removing the passanger kick trim ,unbolting the ecu, turning it around and turning the little knob arround clockwise all the way with a fine screwdriver.
which BTW may be easyer if you are unsure about using a paper clip.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-52710
im too scared to do the paper clip one as i know what will end up happening... i'll electrocute myself! :P:D
now is it the same for R32/33 or are they diff?
***EDIT
also... once u turned the nob or whatever around do u have to turn it back and then bolt it back on?
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-52772
The r32 only has the knob I dont think it has a plug for a paper clip to go into.
the knob needs to be in the diag position for the whole time you need it to show fault code's
remember to turn off ign before setting the knob back into its original position.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53333
Originally posted by ex-static
Nope, I d/c'd the battery.. stomped on the brake a few times.. reconnected the battery, took her down the road until I hit the speed limiter.. 3 times :)
I thought that should do the trick :(
I was just hoping it didnt reset my safc settings.. doesnt seem to have :)
I really don't think it would have done too much.....the proper diagnostic tool is needed and after the reset there are certain driving processes it needs to help the computer 'learn'.
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53513
hey DAMQIK, can u confirm that the following diagram is correct:
|O|OO|OO|OO|
|X|XO|OO|OO|
the pins marked "X" are the ones to put the paper clip through? coz i tried doing that and couldn't put it into diagnostic mode. the bottom left marked X were free, no wires were in them. some of the others had wires in them (for the alarm i fink).
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53658
Guys! Guys!
The R33 is a little more simpler. Now, I may not be 100% on all this as I haven't done it for a while...
Okay.
Remove the kick panel on the passenger side (below the glove box). You'll reveal the computer.
Take the computer out very gentlely (its not hard, becareful of the looms and wires).
On one end of the computer you'll see a white switch, circle shape, get a small flat head screw driver.
Turn the reds on at the ignition.
turn the circlular switch oppositelock, again gently. look at the dash board, you'll see (on a series 1 gts-t) the check engine light flashing. If your getting 5 slow and 5 fast repeated flashes (it will loop) the system and its sensors are all okay.
You'll need the codes if your getting anything other then this...you can get them on the net...meggala's site might be a try there.
turn the switch back to its original postion. You'done a basica computer reading check AND reset the computer.
I would only do this if you can spend at least an hour driving on a highway so the computer can learn some good open running maps...no good doing it for 5mins......
cheers...just check on the process of turning the switch, it maybe turn switch, reds, turn back to get the result.......as long as you return it to the oringinal postion the car should be fine.
ANDREW
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53754
|O|OO|OO|OO|
|X|XO|OO|OO|
the pins marked "X" are the ones to put the paper clip through?YES if X's are towards the rear of the car
coz i tried doing that and couldn't put it into diagnostic mode. ? DID U TURN ON IGN PUT CLIP IN FOR 3 SECONDS AND THEN REMOVE CLIP?
the bottom left marked X were free, no wires were in them. ?the ones you want will have wires in them
some of the others had wires in them (for the alarm i fink) NO THERE FOR THE SEND/RECIVE FOR A DIAG COMPUTER.
To show you I pulled the plug out of its holder
The pin's of the plug you want are closest to you, on your left if you are facing toward the front of the car,
as in the picture below SORRY its not in focus.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53824
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
