Hi all , out of curiosity does anyone have a GT3076R with the real Garrett GT30 integral wastegated turbine housing and the HKS cast low mount manifold on a GTS25T ?
I need to know if that wastegated turbine housing misses the near side engine mount - and anything else that can't easily be relocated .
The only running example I've seen is the woolafs ext gated GT3082R and he said minor mods were made to the mount in his R33 .
I have one of these manifolds but no adapter or ext gate so I suppose a blanking plate and the IW housing should work nicely . BTW - don't want to start an EW vs IW discussion here , for me 0.82 IW is fine .
BTW Woolaf , you don't need the spacer plate with this exhaust manifold do you ?
Cheers Adrian DP03 .
There is definitely no spacer on there disco.
I suspect you may need to machine the engine mount a whisker for clearance just like on the ext gated units.
Since you are swapping on your shiny new 52 trim special order you really should replace the manifold studs while you are in there. This will give you the chance to dummy fit the HKS manifold (that you really should use!!) and see what clearance you have.
I gather it's the compressor housing that gets a bit cosy with the engine mount when using the HKS manifold .
Yeah I figure it probably isn't any more trouble to plumb up a turbo on the HKS manifold than the std one since you have to make a dump and inlet pipe anyway . From what I remember of your car the turbo sits further back and almost below the manifold so a bit more stealth I suppose .
Actually thinking about it your GT3082R has a larger T04S comp housing than my GT3076R's T04E one so may clear as is with a bit of luck . Was much removed from the mount or its bracket on your car ?
I was intending to buy genuine manifold studs and gasket/s , if anyone has their part no's - thanks .
Also is the space behind the turbine housing adequate to fit in an IW type dump pipe with a reasonable radius bend ?
I was lucky and bought an S2 without anti stop brakes so I don't have the pump box and mass of pipes to worry about .
Also have to think about heat shielding , did HKS originally sell those manifolds with heat shields ?
Cheers , Adrian .
Edited by discopotato03
From over the pond though this one doesn't have the proper GT turbine housing I reckon .
http://forums.nicoclub.com/zerothread/4239...ernal-wastegate
A .
Noted the pantz party , LOL .
But there's more , from the same site .
This has some interesting stuff about Holset turbos on RB engines and an Apexi cast RB manifold I'd never seen before .
On the second page there is a pic of an RB25 wearing an Apexi manifold with a HX35 , it also has a GReady type inlet and I noticed the TB indexed around I suppose to make the throttle cable reach it .
http://nico.zeroforum.com/zerothread?id=306777&page=1
Just on the HKS manifold a few have been sold here and the "Kits" have been broken up at times .
She'll want to strangle me but I don't suppose anyone is selling the adapter and waste gate to suit the cast low mount manifold ?
A .
Cheers , Adrian .
The compressor gets close but it is only a whisker needs to come off (if any at all). I made my own heat shield with 1mm aluminium with basic hand tools so with some basic workshop tools you could make up something pretty tidy. With a smaller compressor cover you might come out with nothing to do. Either way it isn't a big deal when you are already in there.
There should be plenty of room for a new dump as the manifold is a low mount vs side mount. The radius on the dump should be more reasonable than on a factory manifold.
Re the engine mount it depends on whether you have a 100mm or the smaller inlet on the housing as to how much engine mount you grind away.
You'll have to grind away the alloy engine mount cover as well.
The HKS low mount [and you are dead set correct Wolverine in calling std manifolds side mounts] actually gives you more room to play with - once the engine mount is modified. I have a SII with ABS and it doesn't even come close. The biggest pain is the A/C hoses running along the subframe. They are a bit close but you can make up a neat alloy heat shield [i used stainless sheet] and that helps. Never ever seen a HKS cast low mount with a heat shield attached, I know they have mounting lugs for one, but never seen one.
Not sure about your IW exahust housing room, but there's no problems with the WG housing hitting the motor, the HKS manifold mounting position for the turbo is kicked out at the rear a bit, the turbo doesn't sit parallel to the motor, so you loose out on the comp side - thus the engine mount mod - but gain on the exhaust side.
The last pieces of my turbo are on order , the 0.82 housing and the large canister 14 lb actuator . I reckon 14 pounds should be a good starting point and with the 0.82 IW GT30 turbine housing should not be light switch anyway .
I must remember to ask Michael to make sure the housing has the larger flat valve though I think all they do now don't they ?
I suppose with the turbo mounted lower down on these HKS manifolds it's easier to get the water outlet line facing upwards and I wouldn't mind it going around the front of the engine RB26 style .
Yes no one has ever seen the heat shield for those manifolds . I might try to get some of that aluminium "quilted" blanket material and make something out of that for the manifold and turbine housing .
I don't suppose Ford had anything made for this style of housing and dump on XR6T's ?
I'll duck into John Robinson Nissan at Rockdale tomorrow and order the exhaust manifold studs and the manifold gasket .
My manifold has four good mounting studs for the turbo but I'll need that gasket as well .
In time , cheers A .
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
