mmm, beer...
some of those formula cars are tiny, eh? That's why I had to give up my F1 career, nothing would fit a 100kg 190cm bloke.n We still have plenty of trouble fitting cage, race seat and helmet into the 32 gtr.
TEGA and AVESCO were pretty clear that they were going to keep v8s a closed shop, said they needed to protect the investment that Holden and Ford have made in the category.
SO if you wanna watch more than 2 cars racing (if you can call it racing...) you'll have to watch Procar....and speaking of which its at Oran Park this weekend.
  • Replies 67
Too far to drive, but I'm off to sandown to cut laps with the maserati club. Just wish I had a decent camera. They are so swish, the BBQ is $25 and is really a spit roast luncheon to the poor among us.
Hoping the rain buggers off and I'm in the mid to high 1:20s
http://www.ls1speed.com/engine12.cfm
Search on Google, there are 100 places in America that can build you a nice 427ci LS1 from off the shelf Chev bits and I know this may be difficult to understand, but a small block engine is a small block engine no matter how big you stroke it... It isn't a big block, unless it is a big block.
Next time your are in the pit at a Procar meet, drop over to the GRM pit and I will show you the CAST IRON BIG BLOCK CHEVY in the Monaro. There are no LS1 parts anywhere near that engine.
If i'm not mistaken the first year the monaro raced the 24hr it was 7 laps behind the leading porche when it got shunted up the arse and had to retire.
Regards,
SKYLINE....
Hahahahaha, Supertourers having fatter tubs than a drag car, bwahahahahahahaha.
Funny man, you make me laugh! You've obviously never watched Top Doorslammer or Supercharged Outlaws then, how 'bout Pro Stock?
Sydneykid, according to GRM the "Meganaros" (as they call them) run alloy four-bolt Chev blocks of the same specification as the C5-R Le Mans Corvettes. There's no cast iron in them. I'm sure if someone built a Dodge Viper SRT/10-R to the same level then it'd be a fairer fight, the problem is there's not enough companies with the money to buy Ferrari 575GTCs, Lambo R-GTs and Maser MC12 (or whaddever ya call it)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
