yeah sure man, if i can. problem is i only have 1 free day a week, Friday. pm me dates etc etc and il send you my mobile number, il see what events are going on at the track.
are you coming to Abu Dhabi at all? thats where all the action is for racing is these days.
  • 3 weeks later...
Updates... fun
So the 35 GTR has been plotting away, I been soo busy it seems that I just blinked and the thing is making soo much progress...
This whole kit was made inhouse, nothing is imported its all made from pipes, we even make the flanges from big chunks of metal for everything.
Turbos are GTX30's and it will be a 4.2 stroker kit, we just recieved the built transmission from the states also.
enjoy
post-1240-0-74271500-1319073498_thumb.jpg post-1240-0-82732900-1319073507_thumb.jpg
post-1240-0-76937300-1319073534_thumb.jpg post-1240-0-52834500-1319073543_thumb.jpg
post-1240-0-02168400-1319073551_thumb.jpg post-1240-0-93812800-1319073557_thumb.jpg
post-1240-0-34096500-1319073566_thumb.jpg post-1240-0-30183900-1319073574_thumb.jpg
post-1240-0-45366500-1319073581_thumb.jpg post-1240-0-60144400-1319073590_thumb.jpg
post-1240-0-22552400-1319073599_thumb.jpg post-1240-0-86852500-1319073608_thumb.jpg
post-1240-0-96282600-1319073616_thumb.jpg post-1240-0-31802600-1319073625_thumb.jpg
post-1240-0-44478400-1319073632_thumb.jpg post-1240-0-40419700-1319073639_thumb.jpg
"Drift Stance"
This is the stance, the tough bad ass look of you're 500rwhp Skyline drifting infront of a whole country who never knew what it looked like untill you came along.
Hated by many, but when I think about it now they just never understood me, and probably never will.
Long live the dream of tuning and drifting
they climbed from behind, thats actually a fence they made for the event, public road. its made of lots of big stones stuck together.
and this car has taken a turn the the worst now... its been ouside in the sand and heat and paint is stuffed and has no engine or running gear at all.
so it needs attention.
Because Guilt-Toy would put a Toyota engine inside a Skyline???.
:whistling:
damn man give me some credit.
But.. Maybe I will drop in a twin rb25 turbo RB2630 into it.
Poor car. What are ur plans for it. Maybe keep the locals happy and drop in a 2J
i do tune alot of toyota's now, my favorite are the 1fz 4.5 litre 6 cyl's.
put some gear inside them then put a gt45 on it and your up to 800hp at the wheels at 6300rpm max and a happy customer.
the 2jz's are easy to tune, they are such a basic motor, i notice that they just don't respond to boost and tuning as much as RB does, it seems like this engine needs to be punished and treated badly just to get anywhere with them and they are lazy revving engines, but they work and I sure I do like them for what they are.
The Toyota 5.7 litre quad cam v8 is a nice engine, here they come in the Lexus LX 570 and the new Toyota Land cruisers, we do supercharger kits for them and I tune with Unichip, they sounds nice and drive good... they are really nice.
I don't do any 1j's or anything but I do tune some of the older toyota v8's with motecs or autronics on them, NA they are really shit house but they do the job.
Engine model: 1FZ-FE
Inline 6 cylinder DOHC
Displacement: 4,476cc (4.5 liter, 273.1 cu. in.)
Combustion Chamber: Pent roof
Power: 165 KW / 4,000 rpm Max.
Torque: 387 NM / 3,600 rpm
1996 output [sAE–NET] 158 kW @ 4600 (212 HP @ 4600)
1996 Max. Torque [sAE–NET] 373 N.m @ 3200 rpm (275 ft.lbf @ 3200 rpm)
Sequential multi-port fuel injection system
Head: aluminum alloy
4 valves per cylinder
Valve angle: 18° 20'
Intake cam: chain driven
Exhaust cam: gear driven from intake cam
Intake valve: Open 5° BTDC, Closed 40° ABDC
Exhaust valve: Open 40° BBDC, Closed 5° ATDC
Firing Order: 1–5–3–6–2–4
Block: Iron
Bore x Stroke mm (in.): 100 x 95.0 x (3.94 x 3.74)
Compression Ratio: 9.0:1
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
