Croydon's Do It Again!
White 35
 Share
Jim at Croydon's has done it again!!!
Ive been watching everyone tune their cars locally and in the USA for about 6 mths now. I didnt rush these mods and originally I was going with a base Cobb map 1 tune to match my midpipe etc but after watching 09GTR work with Croydons the custom tune is the only way to go.
Aside from the car obviously being more powerful its the perfect torque curve that makes the car more exciting to drive. VDC must be to R mode under full power otherwise TC cuts the throttle.
So the mods are:
CBRD Midpipe (the best midpipe ive ever heard - zero drone and under throttle sounds unreal)
Mines filters and
Custom Cobb tune from Jim
Standard the car put out 295kw. But now the car is putting out an easy 340kw (i think 15 pound boost) at the wheels, there is more power to come from these mods above but we backed it off until we can get some better HKS plugs.
Tonight the car ran 3.3 sec to 100kmph with over half tank of fuel. Didnt get it off the line perfectly but 3.3 is good enough for now and this should translate into low 11's. And the car has only 1600kms on the clock.
Next up - Actuators, HKS Boost controller, high flowed catted turbo pipes, GFB Blow off valves and Endless MX72 Pads all from Croydon's.
Highly recommend you speak to Jim at Croydon's if your thinking about some simple mods.
So the mods are:
Mines filters and
Geez, CRD must be good to make you go fast White 35!
  • 3 weeks later...
Thats awesome for such a few simple mods, must be very happy man.
yeah its certainly a lot more exciting to drive. the car only has 2600kmson it and as the kms go up i think its getting faster. only negative is that it comes on boost so hard at 3-5500rpms and then boost falls away slightly. im going to work with Croydons trying some new Cobb tuning to see if we cant get more consistent boost to the redline. The car is a complete handful in damp conditions and just spins the wheels in 1st & 2nd gear.
Maybe have to do Boost Controller and Actuators etc.
Just ordered Stillen Sway bars from Forged Performance in the US and H&R Wheel Spacer kit from Perrin Performance in the US.
I'll have them installed in a few weeks and report back the handling changes.
Plus i want a set of these rims!!
Volk Racing Hi metal bronze RE30 19X10 +30 and 19X11 +20 or +25
Hoosiers 295/30/19 front and 315/30/19 rear.
$4190 shipped to Australia, maybe better if group buy
Sharif at forged performance, about to get some for myself, aussie dollar now better than when I was first considering this.
yeah im still giving thses rims some serious thought - although the Zele rims are sick as well... i recon the $$ will get a bit stronger as well - before it comes crashing down again! great time to be ordering from the US.
i dont drive a 35 but plan to buy one in the future - as for jim @ crd...u got that right :(
ive taken both my gtr's to jim & nobody comes close (ive been around to 'other' tuners & it has always been chalk & cheese)
i dont drive a 35 but plan to buy one in the future - as for jim @ crd...u got that right :blink:
:happy: Spot on Marko R1 - Jim know's his Nissan's Our R33 - 2 records - OP South - 46.81 and EC - 1.44.19 still on 20psi, can't wait till finished set-up!!
:) Spot on Marko R1 - Jim know's his Nissan's Our R33 - 2 records - OP South - 46.81 and EC - 1.44.19 still on 20psi, can't wait till finished set-up!!
i remember the last time we discussed your lap times, low 40s at EC is a fantastic time :happy:, u were running 300awkw if my memory serves me right?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
