Hey Guys i just got this photo of my Car and im in love with it, except the fact that the car was dirty, is it possible that anyone could remove the dirt from my Car and keep it the same good looking picture?? If you can Then i would be very Grateful!!
Edited by Zaver
https://www.sau.com.au/forums/topic/287998-photoshop-the-dirt-off-my-car/
I haven't contributed to the Computer art section for a while, take a look and let me know what you think of my 30mins work
the file on its own after being re-touched
and a comparison before and after
Hey Turk,
For this job, i created a duplicate layer and hid the original (just so i don't ruin the original in case i need to start over).
I used the Clone stamp tool as opposed to the healing brush, and sampled cleaner areas of the car that had similar color to the area that i was using it on.
I adjusted the Flow down until i got a level that wasn't sampling too much of the other parts of the car, but enough for the darker clean black to show up and just dotted the dirty areas slowly, some more than others.
Once i was done sampling, some of the lines between the panels (ie: skirt to door, front quarter to door) were very difficult to make out, on a new layer i used the brush tool, set to 100% flow, using pure black color and a very fine point(maybe 3px or so but with feathered edges) and drew in the lines for the creases that seemed to have been sampled over or were just hard to see, i then duplicated the layer, changed the lightness of the layer to +100 in the hue and saturation menu to make it white, and moved it one pixel right/left/up or down depending on the direction of the light.
Then just used the eraser on a large size (something like 50px with a feathered edge and flow down around 16% to rub away at the white and black lines i had drawn until they blended in enough to look like the actual lines of the car should.
Finally i merged all of those layers once i was happy with it and duplicated the resulting layer, set the layer style to multiply to bring out the dark tones, decreased the opacity of that layer until i got a nice smooth black that wasn't too dark (just looking at the paint and not the rest of the image).
Then used the eraser again on quite a large size, around 70px or so with a feathered edge, and on 100% flow to remove the majority of the out side of the image leaving just the car (keep in mind the original merged layer is still back there).
And to finish, i decreased the eraser size to a few different sizes using around 30% flow, depending on the area i wanted to erase, and started rubbing the paint sections back where there were reflections, as well as through the window and on the driver, the rims, headlights, tail lights, just anywhere that should be shiny.
And that is is for the most part, i probably made some alterations here and there, i think i added a gradient down the bottom to create the shadow you would see going under the car, but that is the gist of it.
-Steve
Hey Rush, that was actually a really good retouch, I'm guessing you used the healing brush? Mind taking me through how you got it so clean? I tryed to retouch it but had no luck on getting it as clean as you did!
  • 1 month later...
Haha the wonders of photoshop :thumbsup:
And here i was coming into this thread to have a laugh why you wouldnt just clean the car and take more photos. :thumbsup:
They are some good action shots. Some good touch ups as well. Shame im not on my own comp or id have a go as well.
shh, i couldnt b bothered using the pen tool to neaten up those edges, no1 would have noticed if you didnt point it out, damn youuu
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
