Got rims starting to pile up people, need help getting rid of them...
17" x 8" +32 Genuine Volk 5 spoke rims in mint condition, Silver with blue insert (between spokes) 5 stud $1k
17" x 8" & 9" Genuine Sparco mesh style with dish, not perfect condition but good mild fitment, 5 stud $1k
18" x 9" & 10" Veilside Andrews 4 & 5 stud, good condition, killer cult rim $2k
19" x 8.5" & 9.5" Speedy rims with 235/35/19 tyres all round (front killer, rears average) excellent condition. Black centre, polished dish, 5 stud $1.5k
will try get pics up asap but in mean time can send via mms if send mobile number to my pm.
No messin around, if u know ur wheels you'll know they're reasonable prices, tyres can be negotiated depending on stock at time & sizes required :P
Located in SA
Get on it peeps :D Cheers
https://www.sau.com.au/forums/topic/288001-rims-for-sale/
The Sparcos got sold, but these are the Volks :D
Hi, Everyone
I am chasing one or more of this Volks Challeng 18x10 offset +20 for track use. They were made in 1995, a bit heavy but I use them with wets anyway.
I am also chasing one of Advan Racing Gold with blue ring ( RG II, I think) in 18x7.5 offset +31 see picture.
Anyone can help??
Alex
Mordialloc 3195
0439818008
https://www.sau.com.au/forums/topic/288001-rims-for-sale/#findComment-4847484
Hi, Everyone
Anyone can help??
Alex
Mordialloc 3195
0439818008
Ok........ Ummm, goodluck with that mate but this isn't a 'post what u need here' thread.
Think there's a 'wanted to buy' section on here that might better suit your enquiry :D
https://www.sau.com.au/forums/topic/288001-rims-for-sale/#findComment-4853390
Where are you located mate? Pretty interested in the volk rims.
I'm in SA mate. Adelaide Hills
What exactly do you have left in 18" please?
Minimum size 9.5"max 11"
Any offset
What do they weigh please?
18" Veilside Andrews. 9" front 10" rear.
unsure of weight, +36 & +48 offset
https://www.sau.com.au/forums/topic/288001-rims-for-sale/#findComment-4891308
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
