I'm assuming you have seen my set for sale below:
http://www.skylinesaustralia.com/forums/Fs...-G-t279581.html
Not the perfect widths and offsets for a coupe but certainly an improvement over factory and at an affordable price too.
Happy to do a test fit if you are in Brisbane.
Otherwise if money is no object then get 9" and 10" F&R with +22 offsets. Just be prepared to pay over 4K including tires if you were to order brand new.
https://www.sau.com.au/forums/topic/288005-volk-gts-rims/#findComment-4826651
From the web site showing the 2009 available size chart:
19x9.5 +23
19x10.5 +18
Roll the rear guards to be on the safe side. There's a little camber adjustment in the rear, which should help make the wheel fit. You should be able to run a small spacer on the front too, if you're aiming for a wide stance.
19x9.5 +14 on the front will probably be pushing it unless you run aftermarket camber arms.
https://www.sau.com.au/forums/topic/288005-volk-gts-rims/#findComment-4827640
ive got them on my car
19 x 9.5 + 8 on the front and 19 x 10.5 +17 on the rear
you will need front / rear adjustable camber kit
i am thinking of selling mine, they are in perfect condition. interested?
-mark
Edited by BLISTC
https://www.sau.com.au/forums/topic/288005-volk-gts-rims/#findComment-4828131
Why is this? When I run the wheels I am looking at 18" x 9.5 +12 through the offset calculator, it says inner clearance will be 1mm less and outer will be 37mm extended. I saw some 18" x 9.5 +25 Rays on a V35 coupe at a car yard and the offset was pretty weak - could easily have done with 10mm more.
Can you 100% guarantee that 9.5 +14s will hit the guard? If so I might have to go for +20s, but they have less dish :)
I want to go same offset front and rear (not big on the staggered look and want to be able to switch around wheels easily).
https://www.sau.com.au/forums/topic/288005-volk-gts-rims/#findComment-4841129
ah forgot to add that will most likely be stretching some 245/40/18s over the 9.5 rims, so will have a sloped sidewall - do you think this would then not foul the guards with 9.5 +12s?
https://www.sau.com.au/forums/topic/288005-volk-gts-rims/#findComment-4841133
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
