Hey guys,
im picking up my R34 on friday but iit just occured to me this morning that my VIN and Engine number do not match. does this mean that the engine has been swapped in japan??? thanks.
Also, i have had the VIN fasted and it all matches up, but now im unsure bout the engine.
The VIN is: ER34010313
Engine number: RB25-292468A
https://www.sau.com.au/forums/topic/288017-vin-engine-no/
If you get a "fast" of your car then it will tell you the engine # of the engine that the car came out of the factory with.
Cross check those to the actual engravings in the engine bay, if it matches fast then it should be the original engine. I forget where the engine # is engraved... but from memory it was not all that easy to find but it may be different for r32 compared to 34 etc.
Edited by r32line
https://www.sau.com.au/forums/topic/288017-vin-engine-no/#findComment-4827182
ummm, i don't ever recall fast showing the engine number of the car.
and after looking through the fast thread i can't find anything either. but i will have a play around on fast leter on and see if i can find anywhere in there that shows it
https://www.sau.com.au/forums/topic/288017-vin-engine-no/#findComment-4831004
