  • Replies 75
most of the cars couldn't be complied?? i thought that all the cars there were complied already??  i visited them a couple of times .. had some nice ones .. had some shitty ones ..
Correct a mundo. Thats what happens with the new RAWs ssytem. Its too hard for most dealers to make a buck anymore, and they are out of business.
Motorcity is one of the few decent dealers left. Who also knows how long they too will last.
Start watching those skyline prices begin to rise my friends. Demand pushes the price up, especially when the supply curve begins to fall.
Paul (Boost King).
sorry, back on topic - this is a real shame, as Simon had already bought the full RAWS package to start complying under the new scheme, and was getting ready to get permits to import the R33.
On an upside, as Boost King points out, at least now the price wont continue to drop for imports - and hopefully modded cars will start to better reflect their true worth (cost to build). that is of course, until they are 15 years old.
Just had a thought, maybe the govt only wants OLD cars on the road - yep thats gotta be it:)
LOL thanks Steve! :rofl: Yeah, I only signed up a YEAR ago!! :)
When Matt and I were doing promo work for Simon at the XHP Show, he was talking about selling up and going into compliancing - next thing we knew, Turismos were gone. No word as to what exactly happened though....
What happens when they are 15 years old?
NitRaTe, how much do the compliance plates cost, and how much is it to get an evidence pack under the new RAWS scheme, and would you be able to privately import a car and get it complied by other than a RAWS approved compliance place, if it is less than 15 YO?
I know that you are still required to make the cars meet the standard that apply to cars through the RAWS scheme, but as it is outside the scheme, there is alot less evidance required, and you dont have to have govt approval to comply the vehicle - alot less red tape, and middle men, means alot less $$$$.
If I am completely out of left field, please let me know what the truth of the matter is, cos this is just my understanding/personal assessment.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
