  • Replies 75
Well, when i signed up i didnt know there already was a Miss 33, oops, sorry Miss*33, No im not a she male, last time i checked i was definately a girl. I know that info, bcoz my boyfriend is in the game himself! And my job pays very well for what i do, which is hardly anything. Maybe before, everyone starts shooting off saying im a she male or a clone, you all may want to get to know me a bit better. Who knows i could all save you thousands of dollars, when you need to fix your cars. Remember its who you know, not what you know!
:P no one got the joke about the job as head waiter sucking.....
Miss 33, sorry if I offended, and a belated welcome to the forums.
No one meant to offend, its all pretty friendly in here, and I suppose we overstepped the mark cos we dont know you. dont be put off though, everyone is very friendly here:)
Except hippy who likes bitch fighting:p
Turismo were a bunch of dorks anyway.
When I was shopping for a GTS-t, no one came out of the office to serve me. When I finally pulled someone out of their chair to help me, they weren't very informative. I asked to take one I was interested for a test drive, he replied "show me your cheque book and you can drive it". Idiots! How could they ever expect to sell a car that way.
Lost my sale.
Paul
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
