hey all...
been scratching my head at this one since i got my car back from tuners.....just neediing to know what is a safe amount of knock for a tuned vehicle.
what is your oil temp (with oil cooler) max on a hot day and whats safe???
what is your water temp on your pfc controller on a hot day max out at, and whats safe??
cheers in advance,
my water temp is at 81 with a alloy radiator
my knock is about 10-15-20
and when i was drifting at winton my knock would be about 15-20
and temp would be 81 usual on a sunny afternoon :D
was just thinking this today as i noticed my safcII reading a bit higher then it normaly does.
when i first installed it i didnt think the knock function worked coz it always stayed on 0, then after about a week i noticed it would read 1 or 2 & after a long drive it read up to 12 but today after slapping it around corners in the wet lol it was reading 16. all my readings are at idle its never read anything other than 0 under load.
does this sound fairly normal?
Knock up to 50 is quite fine under full load, i.e. 3rd/4th up a Hill on a Freeway, etc..
Water temp ideally should be under boiling point, but best under 90 degrees, because at 90+ timing gets pulled back 5 degrees, more or less depending how the powerFC is set up.
Oil, you would want it under 100, 110, I've seen mine go up to close to 120 on a skidpad sitting on the limiter in 2nd for quite sometime.
With an good oil cooler, your temps should never past 100, and below 80, i.e. the oil cooler setup is also running a thermostat, there's nothing worse than 'over cooled' oil.
not sure about the rest but water temp with thick radiator sits at 86C cruising ... r34 thermostat opens at 82 so that's normal (bit lower for R33s as the ts opens at 76)
Is that true that the PFC pulls timing if temps get over 90C?!
My R34 consistantly runs in the 90's during summer since I installed a FMIC. I pulled out my radiator yesterday in the process of replacing the timing belt, and discovered it was in very poor condition with many bent fins... Might explain things!
In any case if it pulls timing I think I need to look at getting a new radiator.
there is a water temp timing trim option in the power fc yes. what it is set at I cannot tell you as it can be changed with dataglogit.
I think its time to change your location guilt-toy, but from the youtube videos i have seen your avatar is spot on :)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
