It's only a photoshop - well i hope to god it is - the current STi bug eyes look wicked. That car looks like a F*CKING HONDA!!!! it's YUCK! look at the grille! it matches NOTHING and the lights look like they're off a daihatsu YRV or something!
infact yes i think they've photoshopped it with YRV headlights! ick!
https://www.sau.com.au/forums/topic/2881-new-wrx-design/#findComment-50948
Guest Impul 25T
Testament to Nissan for coming up with the 4 hot plate tail lights..... seems everyone wants to put them on new cars now(inone way shape or form).
As for the WRX, I think that if the so called 206kW limit in Japan has been thrown, it would have a little more pep in the engine dept. I agree with Ryan tho, def looks photoshopped. If it was to be realeased in two months, there would be actual photo's of the car around.
https://www.sau.com.au/forums/topic/2881-new-wrx-design/#findComment-50956
did ANYONE notice, both pictures of the car, have DIFFERENT wheels ?
The big pic has like standard 16's in silver, and the bottom looks like hyper-chrome 18's and completely different design.
had me fooled thought. DAM GOOD photoshop work!
the rear wing is a bit suss also... :D
https://www.sau.com.au/forums/topic/2881-new-wrx-design/#findComment-51090
Loks photoshopped... funny how the lights don't line up, one cuts into the bonnet a lot and the other dosen't. Plus I don't think they'd have designed the front with a little triangular piece between the lights and the bonnet and the front grille. If they did that's jus stupid.
Looks likie a potential rice car anyways, so it can't be an imprezza... has to be a honda, daihastu, daewoo or other.
https://www.sau.com.au/forums/topic/2881-new-wrx-design/#findComment-51519
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
