Just finished Brembo conversion on my car
documented some details and so on.
and took alot of pics
Brembos Finally arrived
Closer look at the front.
With the Rest of my stuff
Slotted EBC rotors and EBC red stuff brake pads
Standard Front
Standard rotor vs new 324mm rotors
Fronts installed
The fronts where pretty easy and straight forwards but you must use the brake lines off the 350gt as it will be a straight fit
using the brackets
The rears needed abit of modification on the dust cover and the brake lines needed some custom mountings
dust covers designed for the standard rotors
Had to get a nibbler and modify it
Rear brembos installed
*the standard caliper blots coudlnt be used cuz it had a finer thread u can either use OEM Z33 or aftermarket caliper bolts
https://www.sau.com.au/forums/topic/288150-m35-brembo-brake-coversion/
So stolked to see that Danny! Its exactly what I have been planning.
Can you give me the part numbers for the rotors you used. Also did you need to to make a mounting adaptor for the rear calipers, or just make room with the dust tins?
Ben.
i can provide you all the part numbers
but only mod to the rear was the dust pan and different bolts
no mods were requiered to fit the rear
price wise would set u back 2.5K-3K
obviously i didnt pay that much for it lol
going to finish off blddeding the brakes today
so ill let u guys know how it feels
is there a chance youll have to upgrade your master cylinder?? else youll be pushing VERY far on the pedal before it grabs. might need to get the master from a brembo equipped V35 (if they are different)
too much movement..
it's not hard enuff for brembos
A larger piston master cylinder will help but if your pedal isnt too low, see how it goes.
Have you bed the brakes in properly? Go for a thrash through the mountains and they will feel better after, promise. If not, you might just need to re-bleed.
I was hoping for a better review of the EBC reds... :thumbsup:
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
