What are you guys paying for Brembos? I have a set of D2s on the front of my Stagea - cost about NZ$2k but I think there is a group buy on this site run by R31Nismoid.
Would rather pay 2k and no import var tax than 800 and half of car value in import tax.....
  • 10 months later...
Hey guys..
Just digging this up as I need some clarification.
For those who have performed the Z33 / V35 Brembo caliper upgrade, did you upgrade the brake lines as well?
Obviously upgrade lines is preferable but can I get away with the standard lines?
Cheers guys.
Found it:
Stoptech stainless steel braided lines
Purchased from Concept Z performance
Designed for G35 sedan 03-06, coupe 03-07 (I think they were for G35X if they make different ones for those models)
Part Number for front and rear set G35-950.42004_950.42503
Fitted to M35 ARX with 350Z Brembo's - straight fit, no drama's, no cable ties; was able to use supplied bracket mount
Cost me $150 plus postage (2 years ago) for the set
So those have 3 parts not 2? The G35X was the awd one, so they should bolt on, just like you described.
Maltech wanted $700 the set back when I fitted mine... Thanks for that Adam, we should get a group buy started on them.
What do you mean by 3 parts Scotty? They are full replacement - single braided line from solid line to caliper. I'll take some pics over the weekend some time.
I guess I could organise group buy, however seeing that I already have a set there is not really anything in it for me...unless you want to organise front and rear sway bars for me Dale?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
