Stock- 296 x 24mm fronts
R32 GTR non vspec - scotty is very right - 296x32
R33 GTR - 324mmx30mm
taken from dba. don't know about minimums. There are some dodgy discs out there for sure. I'd say 2mm wear and its time for something fresh.
Noob.:P
You measured yours...?
guess what they are...
I checked the thickness when I put em on and before I bought em.....but next time I get a wheel off I'll check...pretty sure they are standard R33GTR...not the V-Spec!
http://nisoctt.forum...-up-information
Edited by Jetwreck
ok i lost all the info i put together and had to do it again :( LOL
same sized brake pad for all R32/R33/R34 and 350Z with the brembo's....
R32 GTR disc is 296x32mm with height of 54mm
R33/R34 GTR disc is 324mmx30mm with height of 53.8mm
350Z brembo's is 324mmx30mm with height of 49mm
Edited by WAGON_BOY
http://www.project-mu.co.jp/e/files/SCR_LIST.htm
P.S. Alex(PN-Mad) now has me thinking....I am really going to have to take off my wheels and check the rotor thickness...not admitting defeat yetph34r.gif!
I don't get what the concern with brake pad's is .....you have ????? brakes on your car.....ring a brake place tell em I have ????? brakes and what pads do you have to suit!
http://www.project-m...es/SCR_LIST.htm
P.S. Alex(PN-Mad) now has me thinking....I am really going to have to take off one of my wheels and check the rotor thickness...not admitting defeat yetph34r.gif!
meh... 2mm isn't too much to worry about anyway...
war have been fought over less...:pirate:
lol :teehee:
Let me summarise for wagon boy
when upgrading brakes you can do the following-
1)better quality original size pads and rotors
2)commercial big brake kit for G35/Z33
3)Z34 Akenbo kit ex US
4)r32 GTR conversion / possible upgrade to 324mm
5) z33 Brembo conversion
6) R33/34 Brembo conversion
between everyone here, all those have been done. std wheels won't fit- you need aftermarket.
most people worry about the fronts but not the backs. All will cost different $ depending on what you decide.
ive got the AXIS 18" rims im sure they will clear the callipers or is it the offset thats wrong???
cos i have a custom 324mm disc with RX7 S6 4spot callipers on my 808 wagon and i run a 16" rim.
Offset- the side of the 4 pot will hit the spokes- the diameter of the wheel is plenty big enough.
easist way to check - put a wheel on a z33 with Brembos or a R3* with Sumitomos
We know arx rims don't fit, my s2 17's dont fit - that being said, I don't know if ppl have tried the axis rim.
Edited by PN-Mad
lol :teehee:
use the AP big break kit for a 350z nuff said
Ap are up there as one of the best they make break kis for F1 for fs sake
Why anyone would need massive kits like those on the street I have no idea, best to keep the rotating weight down. I can get abs to kick in with my little toe with just 295mm disks.
Good slotted rotors and a good set of pads is what you want, braided lines will improve the feel. I got my r32 callipers for $300, the full set.
lol :teehee:
to be honest, i went with number 10] got some slotted rotors, and good qfm pads.
mine stops fine. and l can still get ABS on fine.
my theory is, if i change the brakes, and know that I can start braking alot later to stop, i'll over calculate and put it into a wall lol.
where as now, i know i have to stop a little early - i concentrate more.
+ me and scott were discussing this, and i rarely rely on breaks anyway
by no means sell the brembo's.. you already have most of the stuff(or the more important anyway) might as well just do it.
however, i honestly do think that the BC's and Sway bars are more important - but thats me, i rarely rely on the brakes, and when i do. they stop fine. the single piston is big enough.
Scott you never stop lol
The way your car is lowered you've probably lost the ability to stop it anyway :P
On a serious note with the standard callipers and rotors + only Nismo pad's I found the brakes pretty good! The R32 GTR Calliper and rotor set up was definitely better.....the Brembo's were better again....have yet to test braided lines!!
at least i dont blow things up lol. oh wait..
car stops fine craig. oh i gotta give you a call.
    • Something to note, on an aftermarket BOV, it's quite possible to end up with the worst of both worlds, where on light throttle, there isn't enough force to open the BOV so you get small reversion and driveability issues, and with the venting to atmosphere, it dumps a lot of fuel on shifts. Realistically, dumping to atmosphere under power isn't a major driveability issues, compared to the issues of stalling from reversion. If you're getting up the throttle, then putting the clutch in, say on a shift up, but then don't release the clutch, yes, the engine can and will stall, but, just drive around it, and that's easy, let the clutch out in the next gear and the car rolling will keep it all running / going.who wants a hard hit of throttle and then to just let the motor idle anyway?   Main issue for driveability is blipping throttle and it wanting to stall, like when parking or trying to move in slow traffic.
    • As in they quoted one price, you mentioned the exhaust, and they promptly added $200 on top? Interesting.
    • Note that I'm not suggesting this is a great idea. Just saying that it is something that could be done to achieve a better outcome than the more shit ideas will provide.
    • I'd try removing it, connecting hoses and see if that helps. Depending on specs, it could actually be restricting the flow(it also might be helping).
    • Yes, that's a hybrid BOV. The adjustable spring load ones are about making teh pressure build up higher before venting, so you get a more agressive whoosh. That is not what I meant or what you want. By "restricting", I don't mean "keep it closed until the pressure is higher, then open it fully". I mean "open it as soon as it is required, but only have a small port area, so that the flow rate out of it is slowed down". The pressure will rise to be higher than a bigger ported BOV would provide, but it would do while it is venting. The idea is to slow down the rate at which the replacement eair is flowing past the AFM, to reduce the magnitude of the air flow signal peak, to reduce the amount of fuel that is added per revolution.
