hi guys, just wondering if a car is written-off.. is that an history about it?
let say if im getting a used car, do i know it's a written-off car before?
thank you
cheers!
Hi Mate
do you mean buying one here, or in Japan?
If it's a local car, you get the vin/chassis number, engine number and as much related info and do a REVS or VSR check with your local roads authority - such as Vicroads or the RTA. They will give you a report detailing if the vehicle has ever been written off. There are two types of write offs - one is a statutory write off, these can never be reregistered as they are on a register of written off vehicles. Chances are if a car you are looking at had ever been written off in this fashion, the check would be pointless as it would have had to have another cars identity put on it - ie, dodgy as hell
The other method of marking a vehicles as a write off is a financial write off - where it's not viable to fix the car, the insurance company write it off. The car can be repaired and then inspected by an engineer to ensure it's safe to go back on the road. This is recorded against a vehicles history and will come up on the REVS check :)
Hope this helps :)
Cheers
Aaron
https://www.sau.com.au/forums/topic/288155-write-off/#findComment-4831908
Hi Mate
The other method of marking a vehicles as a write off is a financial write off - where it's not viable to fix the car, the insurance company write it off. The car can be repaired and then inspected by an engineer to ensure it's safe to go back on the road. This is recorded against a vehicles history and will come up on the REVS check :P
Hope this helps ;)
Cheers
Aaron
thanks a lot mate,that explains almost everything..
cos someone is selling me his car, it's lower than a normal market value.. but there is nothing wrong with the car, so i suspect it might be a repaired write-off car..
https://www.sau.com.au/forums/topic/288155-write-off/#findComment-4832671
very easy to go and do the check and find out, it will also tell you if the car is under finance - in which case you would be making payment to the finance company and not the seller :P
https://www.sau.com.au/forums/topic/288155-write-off/#findComment-4832943
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
