Need Help For Track Day!
Hey Guyz, well im planning on going for my 1st circuit track day at winton on the 10th of oct and i wanted some info on the things ill need to get done for it.. Well just few weeks back i came back from drift at winton and i am using the same tyres on my car that i used for drifting as it still has a descent amount of tread left...
The thing u should know is that all my 4 tyres are not worthy enough for the track, so i just need tyres for the track day!!
What tyres for track day are more important rears or front? This is only becuase im low on money and really want to do a track day before i have my exams and then get busy later on..... Should i get like any used semi slicks for the front and descent tyres for the rear??
Would 2nd hand tyres like semi slicks or just some good performance tyres also do?
As said i just need them for the Day so i dont want any fancy tyres... I can use my current tyres for the street as usual!!
Thanks Guyz!!
Edited by Zaver
Fronts would be more important - otherwise the car won't turn corners! if your current tyres are r/w, you should still be able to use them on the track. Otherwise, just get "normal" road tyres.
You (probably) aren't Craig Lowndes, so you shouldn't be going to the track for the first time to pretend you are. Use the day to get a good feel for the car, how it handles at really high speed.
My 2c.
fronts,
you brake (well 90% anyway) and turn with the front.
Personally i would just get a decent street tyre on there. Having a semi on the front with a regular road tyre on the back is asking for trouble as you will be able to chuck it into a corner pretty quick but won't have the rear end grip to keep it all together. Corner entry oversteer would have to be one of the slowest ways around a track as well.
Well then i guess im just going to leave my street tyres for the back and get some good performance street tyres for the front.. Is it ok if i get like 2nd hand tyres with like arnd 60-70% tread in the front?
My 2c.
spot on
if i get my car ready for oran park that is what im doing, first time on track get to know the car i don't care if im the slowest there
If you are short of funds i wouldn't be mixing tyre types - just put 45 -50 psi in the tyres you have now and drive within their limits. Look for a set of second hand slicks preferably on a set of rims and buy them when you can afford them.
I picked up a set of these KU36's from these guys, price couldn't be beaten, great service too! http://www.option1garage.com.au/NewTyres.htm
Dude..awesome link..and a pretty good price too. i got kumhos on the honda .they dont have much of a tread pattern but the rubber compound is sooo nice ,and make for a comfortable grippy ride...funny thing is i do work for and know someone (mates girlfriends daughters dog trainer) who works at melbs kumho warehouse, do you think i can get a good deal...not yet anyways..lol..this price is alrite
So do u think getting a set of Kumho K36 for the front and decent 50% treaded tires at the back are a good way to go? And since the K36 is kinda a semi slick, how is the grip in the wet? Because then i will use the same tyres for my everyday use!!
I'd say sounds good for a beginner,and considering the tail happy nature of skylines i,d be tempted to put the new tyres on the back for extra traction out of corners..
should balance out nicely for learning on a track
get the basic semi slick tyre - such as mentioned the ku36's or falken rt615's
SAU NSW also has a deal on federal's
do not skimp or be a tight arse on tyres.
What keeps the car on the track? tyres!!!!!!!!!!!!!!!!!!
one of the most important part for track days/motorsport
Buy a set of new tyres whether its the ones mentioned above, or a nice road tyre like the federal 595's.
look at it as a safety issue too.
also, out of interest, how much power do you have?
KU36 in a 235/45/17 is 35 per tyre cheaper than a federal through group buy, and 100 less than the falken. Option1garage has them cheaper than any where else i tried...
They seem fine in the wet, have driven in the wet quite a few times on them. Just don't drive flat out(take it easy)
well i guess the Ku36 looks good comparing it to other tyres its even got a better rating.. So ill be getting a set of tyres for the front and maybe some decent tyres for the rear..
Well i currently just have 180 Kw's ... But the current rear tyres im running just dont grip.. even in the Dry!!
Hey RB_Ryan .. Did optiongarage send u the tyres from QLD or u got it from melbourne??
Thanks Guyz!!
I see you've had a lot of advice already but here's mine: don't mix tyres! The difference between even half-worn semi slicks like Dunlop DO2's or Bridgestone RE55's and most high performance road tyres is about 3 seconds a lap (at Wakefield). I know how hard Winton is on tyres so I can only imagine it would be even more so there. A well-sorted Skyline can still produce both understeer and oversteer, even with semi-slicks all round, and if you haven't had much track experience you could find yourself in big trouble.
So, if you're not worried about times, just go with good road tyres and start them at about 38 psi front and 40 psi rear when cold.
I ran Pirelli P Zero's on the track in supersprints for a couple of years before getting semi-slicks and they worked well, although when I finally did get some RE 540's they were indeed about 3 seconds a lap quicker. The new Kumho's with the semi-slick like tread pattern are damn near as good as the real thing, also.
If you do get a hold of some second hand semi slicks, their optimum track pressure when hot is 34-36 psi. Be aware that the fronts can go up by up to 6 psi from their cold pressures, especially on a hot day.
Even with shipping(30 per pair) it was worth getting them sent down... DO NOT SKIMP ON TYRES. I have ~180rwkw, I had advan neovas, i was having serious traction issues, KU36 and a good alignment has helped this. An RB25 has more torque than my 20, so you will get out of shape more easily, so please please please get all new tyres. If i could of afforded it at the time, I would of gotten better rubber, but I am happy with the KU36.
do not skimp on tyres - just get a full set. keep the current tyres for later, or just simply swap them around.
+1. You wont have much fun with semi's at only one end. Get them all round or just replace the dead ones with something similar to whats on the other end if you cant afford a full set.
Pretty sure the Fed 595RS offers more grip than the KU36, but IIRC 595RS = 140 treadwear, and the KU36 = 180 treadwear so in theory the Kumhos should last longer.
cant really compare between brands though can you?
Agreed. Brand means nothing as they all make more than one model of tyre. You need to compare models within the same category.... AFAIK its reasonable to compare: Federal 595RS, Kumho KU36, Falken RT-615, Toyo R1R as they are all street/track crossover types.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
