So what's the plan afterwards? Similar to DECA, i.e ridiculous amounts of alcohol mixed with a twist of soggy popcorn?
Trying to workout whether or not I should stay the night or drive back. My mate isn't coming this time so I won't really know anyone.
You guys won't try and take advantage of me will you?
  • Replies 109
Similar - not quite as insane though. Think of it as a great way to meet new people, or to get to know a bit better a few you've already met.
Im now a maybe as to whether Im coming :D
Will still post the name and details for accommodation this arvo though.
Any news on the accomodation? I've got to work the Sunday so I'll only be staying the Friday night, I'll stick around for a bit afterwards though.
Anyone looking for a room mate on the Friday night? Promise I don't snore!
As i said, im not sure if im coming yet or not.
But I suggest you guys stay either
Here - (Cabins and hotel rooms) http://www.benallaleisurepark.com.au/
Or here - (most WRX guys usually stay here) http://www.topofthetown.net.au/?file=home
Chat amongst yourselves and work it out, then let us know so we can book if we come.
Sorry for the delay guys
Tim, Campbell and I are going to be there and possibly a few others for friday and saturday night. Either at the executive hideaway (we always stay there and it's got lots of room) or maybe caravan park.
Who else?
Who else?
Pick a place I'll book there too, whichever is cheaper :P
Who else?
Yay, can't wait, another big weekend on the drinks!
Perhaps one day I'll stop being lazy and get my car up and running so i can start racing again :thumbsup:
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
