Hi guys,
I remember seeing a post on here somewhere about this but I can't seem to find it- if someone can point me in the right direction I would appreciate it.
Wondering if anyone has run an R32 actuator (10psi) with the stock R33 boost solenoid earthed out and ended up with a stable 12psi?
Any experiences would be great.
Cheers
Chris
Edited by Yeedogga
https://www.sau.com.au/forums/topic/288200-quick-boost-solenoid-question/
Yeah thats the kinda boost you'll be expecting with the r32 actuator. Did the same thing on my 33 except I just ditched the boost control solenoid completely instead of earthing it. Switching from my standard actuator to the r32 item put boost from around 8 psi up to around 11psi, this was with a front mount cooler and full 3" exhaust. I wouldn't want to push the stock turbo past 12 psi just to make sure you're not stressing the ceramic exhaust wheel too much.
Thanks for the replies guys, but i should have been a bit clearer - I'm already running an R32 actuator and getting a rock solid 10psi at the moment with a FMIC/exhaust.
I was hoping to use the stock boost solenoid to switch between 10psi and 12psi. I don't want to run 12psi all the time but it would be good to have the car remapped on 12psi and then use that setting for when I need a bit more oomph.
I think if you have the boost control solenoid operating it will start off runnin 5 psi until 4500 rpm and then the rating of the actuator, r33 being 7psi and r32 10psi from 4500rpm upwards. And the low boost setting isn't adjustable.
Correct me if i'm wrong if anyone has tried this?
Well the low boost setting will be 10psi with the R32 actuator- regardless of whether the electronic solenoid is connected or not.
What I'm hoping to do is get the R33 solenoid to bleed off 2psi when it is earthed, giving me 12psi.
I guess I'll just have to try it out!!
Cheers
  • 3 months later...
if you run the r32 actuator, then you dont need the solenoid, it's pointless
the r32 actuator will give you a prefect 12psi, whichi is about the max i would run on the r33 turbo
here are the spec of the std actuators
Use the air gun to blow compressed air approx A ~ B kgcm2 into the hose and make sure the swing valve controller rod operates.
where
HR32 - A = 0.8 and B = 0.9 kgcm2 which is 0.85kgcm2 (average) which is 12.08 psi
BNR32 A = 0.7 and B = 0.8kgmc2 which is 0.75kgcm2 (average) which is 10.66 psi
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
BCNR33 A = 0.79kgcm2 and B = 0.85kgc2m which is 0.82kgcm2 (average) which is 11.6 psi
if someone can find ER34/BNR34 please let me know
cheers for that Paul :wub: i always thought the r32 actuator was rated to 10psi, i guess 12 won't be too bad.
i have just unplugged the solenoid and am going to hide the dangling plug bit under the airbox so it all looks nice and stock, easier than pulling everything out and blocking off hoses etc i think.
EDIT: in the process of taking out my current actuator.. can anyone point me in the right direction re: removing the pin at the turbo end? i don't want to damage anything.
thanks
can anyone help me? sorry to be a pain :wub:
it looks like the rod is sort of clipped onto the turbine housing, reading around on other site it says to 'pop' this bit off.. but i'm a bit too cautious for that!
  • 1 month later...
on a very quick short / run it might be ok
but after repeated loading up the stock core will be useless and wont perform
the end results would be excessive intake temps causing detonation
r32 actuator with no boost control solenoid = 10psi
r32 actuator with boost control solenoid hooked up normal = 10psi and at 4500 rpm 12psi
r32 actuator with boost control solenoid hooked up and earthed out = 12psi
Edited by MrR33666
no, that's incorrect
from the nissan service manual;
so the minimum boost you can run when using the R32 actuator is 12psi
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
