Heaps Of Parts Rb's, Gearbox's,garrett, Tial Heaps of performance parts, r32,s13,180,s14,rb25 engine,sr20,2jz,rx7
-RB25det long motor 80,000ks from C34 stagea good compression in car, custom high capacity sump no manifolds or turbo etc includes loom moddified to suit plug and play r32 and std ecu $1700 or with out loom and computer $1500
-Garrett 3082R .82 3 weeks old one dyno run mint condition $1600
-Tial Wastegate 44mm v band type one dyno run old$500
-Custom steam pipe manifold to suit RB 20/25 has 44mm tial gate flange and t3 footprint heat wraped same as 6 boost good condition $750
-R32 tien basic coilovers with king springs 12kg fornt and 10kg rear also have std spring rates 1 month old$600
-R32 fr and rear whiteline adjustable sway bars like new $450
-Custom rb 25 inlet plenum suits just jap 80 or 90mm tb also has adapter and std tb fits perfect looks trick =] $600
- Rb25 VPW fuel rail kit and 6x siemens deka 650cc injectors includes rb25 injector loom with plugs to suit $600
-buddyclub P1's 17x8 and x9 with good tires $1100
- white r32 GTR bonnet and grill (aluminium) perfect condition $400
- r32 newish genuine dmax front bar $300
- ca18det ecu - $60
- rb20/25 high mount stanless manifold, brand new never fitted - $250
-ca s13 power steering pump $50
- s13 sr20 turbo brakes with decent pads lines knuckles lwr control arms etc - $150
-s13 sr engine x member $100
-ca radiator gc $40
-sr s13 gc comes with thermos $40
-heaps of turbo bends elbows pipes to suit sr and 25 $20 each
-s14 handbrake and cables $30
-s2 rx7 manual gearbox gc $200
-2jz turbos and manifolds probs need rebuild $50
-s14 greddy air diversion panel a couple small marks dints etc still works good $50
-ca18 loom has one interior plug misisng$50
-set of 4 17x8 skid rims $400
-s14 std steering wheel $50
-s14 std mirrors white $100
-s14 airbox $60
-s14 clutch fan recently serviced and fan shroud $50
-s13 blinker and wiper stalks air bag type $30 ea
-2x cannon mufflers $50 ea
-2x used sr clutches one is nismo solid centre other is exedy sports button average condition might need a machine $50 each
-ca18 auto gearbox tailshaft gc $100
-sr20 manual tail shaft yoke $80
-rb25 top half plenum no tb $30
-s13 clutch pedal and man brake pedal assy $200
-4x16inch r33/s14 std rims 2 are pink 2 are black no tires $150
-r32 nismo strut brace $50
-sr20 std fpr $10
-rb20 std fpr $10
-6 rb20 injectors $100
seriously heaps of stuff need anything ask
will post up more as i think of it
PM me =]
Located on gold coast or ipswich
Hey mate, interested in the RB25. Have you got compression results for it? Does it just need exhaust and intake manifolds and turbo? Anything else? Would you be willing to ship it to Vic?
- ca18det ecu - $60
-ca radiator gc $40
-s14 airbox $60
-sr20 std fpr $10
-rb20 std fpr $10
PM me =]
Hey mate, you still got the fuel rail kit, the injectors, the injector looms and plugs? Keen to take these off your hands, will you be able to organise delivery to Perth?
How old are the injectors and the fuel rail? Ever been fitted?
Would you accept $450 inclusive of freight?
bare 25 is SOLD
sorry mate not as yet still have other interest at asking price..... injectors rrp for 120 ea and fuel rail was 300 thats over 1000 dollars worth of gear with out the plugs speedflow fittings lines etc been used for 3 weeks
I still want the strut brace but you never replied to my PM!!!
hey mate sorry been so busy still here do u need pics? its got red plates and the bar is silver i will get pics to you tonight
pics of the r32 front bar please
will pm you shortly
hey dude cant pm ..not enough posts, have you got any rb coil packs?
yes have a set of super sparks 300ono used for 3 weeks like new
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
