hey guys im currently trying to add some mods to my car and was wondering if anyone had any pics of the mods they have done and instructions on how to do them... all help would be appreciated as im only a newbie with limited experience with cars... btw my car is an 82 skyline hatchback with the l2.4e engine..
https://www.sau.com.au/forums/topic/28828-r30-skylines/
  • 3 weeks later...
leads, plugs and a good coil pack, litually more power. then the exhaust,headers and a 2 1/4" sports systerm. have you got that large sideways final muffler still??
this is good as you can get lost in the other thread if you want this kind of info!
https://www.sau.com.au/forums/topic/28828-r30-skylines/#findComment-610328
  • 1 month later...
also i think i have found a way 2 attach a pod onto the afm... the plastic part which has the air filter in it can easily be removed via 4 small bolts, then all that will be needed is to reattach the mount for the afm to the front holes insted of the rear and make some custom piping and attach an APEXI power intake POD...it should fit but im still checking measurements. will post pics when i start working on it
https://www.sau.com.au/forums/topic/28828-r30-skylines/#findComment-673639
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
