Hey guys.I had my R33 with power fc and basic mods tuned about 25000klms ago.Everything was fine for this time.I had my 100000km service done last week and ever since i get pretty high knock reading on both normal driving and when i give it a bootfull.The engine feels and sounds better than it ever has before.When giving it a bootfull it will read between 70 and 100 on the knock reading every time and when driving around normal i will get readings of up to 50.Can any one enlighten me as to what may be wrong please.This car is my daily and i have to travel about 90kms a day so i dont want to damage it!
https://www.sau.com.au/forums/topic/288280-high-knock-after-service/
You'll lunch it if you don't baby it, need to get it back to the shop and get it re tuned. Anything over 60 is a worry, and 100+ is piston melting time.
Could be something simple like a fuel pump on the way out?
Can't really afford to lunch it.Fuel pump is a walbro 6 months old :D
did they set the timing for you in the service. could have been slightly retarded when originally tuned
Don't know mate.I rang the workshop and he called my tuner Matt Spry who said to bring it down it wont take long to fix but when i called him to make a time he was pretty busy and didnt know when he could fit me in :D
Please drive like miss daisy till the tune/timing is sorted............................
I'll do my best mate.I'm pretty worried about it.I didn't know this could happen after a timing belt change
let it blow!!!....then maybe you can stick a 2lt S20 in it!!!!....take it closer to the original GTR....know what I mean???
Edited by Jetwreck
I didn't know that changing the timing belt could affect the timing. Does anyone know the truth ?
yep it will, as the cas gets removed. I'd say it was either not set after re-assembly, or the most likely case is the base idle was set wrong before it was tuned (say 10degrees) and after they serviced it they set it properley to 20 and it now has 10 degrees more base in it.
Edited by URAS
thanks Trent,
If the person changing your cam belt marked the cas and put it back in exactly the same position your timing will still be out bacasue of the new belt. 'Tell your tuner that your cambelt has been changed and you probably just need 5min of his time to check the base timing - not a 2 hour tune, and he should be able to fit you in (if not get another tuner).
I know it might be what trent said with the cas but has anyone thought about the mechanic taking the car for a testdrive; thrashing it for an hour n filling the tank back up with regular 91 octane fuel? thats why its knocking so bad.
plausible as if u only had quarter tank n he used most of it, refilled with 91octane and cos ur car is tuned for 98, its knocking.
jst a thought!
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
