I know it might be what trent said with the cas but has anyone thought about the mechanic taking the car for a testdrive; thrashing it for an hour n filling the tank back up with regular 91 octane fuel? thats why its knocking so bad.
plausible as if u only had quarter tank n he used most of it, refilled with 91octane and cos ur car is tuned for 98, its knocking.
jst a thought!
if you fill the tank with 91 driving like miss daisy with a tune for 98 will still cause ~100 knock or more the moment you go near a slight incline.
jst a thought!
Na mate,i was there most of the time and he's not as dumb as that.Filled up since then too
If the person changing your cam belt marked the cas and put it back in exactly the same position your timing will still be out bacasue of the new belt. 'Tell your tuner that your cambelt has been changed and you probably just need 5min of his time to check the base timing - not a 2 hour tune, and he should be able to fit you in (if not get another tuner).
yeh my tuner said the same thing.I'm taking the car down there tomorrow.Cheers
Just got back from seeing Matthew Spry.He got the timing light out out and adjusted my CAS.He said it was out bugger all but all is fixed now.A Big thanks to Matthew and thank you to everyone who replied on this topic! :cool:
  • 4 weeks later...
Unbelievable! Went for a drive this morning and got knock readings of 75 and 121 while giving it a squirt in 1st and 2nd!!! Just driving normal im getting readings up to 30.So after matthew Spry adjusted the base timing it was good for a couple of weeks and gradually got worse.Really getting frustrated.
so has it always been like this or just started since the service
if always
then how was it tuned, if its just tuned on the dyno
then its likely to knock on the street, most cars knock differently on the street vs dyno
typically the owner abuses it thru the gears which is different to load simulation on the dyno
the end result is you touch a few cells tht might have too much tming, so these needs to be fixed
if only just started
then check what was changed and adjusted at the service
You need to take your car to a good tuner and get him to check your cam belt timing. If your cam belt timing is out then it will cause knock as well. once the cam belt timing is checked then check the ignition timing. if the ignition timing is okay then its possible the cam belt or ignition timing was out when it was tuned so now that everything is set correctly there are problems.
Stop flogging the car you could damage the car.
Get everything checked including the cam belt timing and then ignition timing and then get the car completly re-tuned.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
